b16a ?? about throttle and clutch cable
I m going to do a b16a swap. i was woundering if i need a throttle cable and clutch cable for a integra in order for the cables to reach the motor. And do i need integra hubs and steering knucks, for the splines in the axles, to line up with the hubs. i know the si is bigger than the hf but i don't know if there bigger enough.
if there is any thing else fill free,
thanks for all your help
you're gonna need an integra throttle cable- i think i got mine for a 1990, and it cost around 25 bucks. your clutch cable will be fine- no need to get another. also, im pretty sure u need si hubs- hf wont work. and dont forget to remove the dust seals from the hubs. I forgot to, and the car wouldnt move at all. its a little metal ring on the inside of the hub (tranny side of the hub) that you will have to pry out with a flat head screw driver. gl
tim
tim
I just did this swap. You can use the stock clutch cable, the integra throttle cable like he said, si hubs. There is no need to get integra hubs. You will need 90-93 integra axles, you will have to either modify your existing linkage (extend) or modify an integra (shorten) or buy the hasport linkage which is perfect. Don't forget you will need to run 4 additional wires for Vtec soleinoid, vtec oil pressure, knock sensor, and 2nd O2 sensor. All the information is provided in the Faq section.
Good luck and congrats!
Origin
12
Feb 3, 2004 06:14 PM
ironchef25
10
Jan 20, 2004 12:26 PM
BoostinDC2
Feb 17, 2002 05:41 PM
