1500$ What to do?
Old May 4, 2006 | 01:41 AM
blumpfish's Avatar
Default 1500$ What to do?
I just recently came across about 1500$, I have an 88 crx si with a gen 1 b16 ys1 tranny w/ lsd
i want some ideas on what i can do in this price range to make the most of my money to make it quicker, it doesnt seem that fast right now, i bet it wouldnt even break into 14s, its completely stock except a CAI, stock suspension, wheels, exhaust , motor, everything .. i am definately getting a high flow cat or test pipe for sure, because i think the cat is going .. and it is running rich..
what can i do most efficiently with that amount of money?
Old May 4, 2006 | 01:44 AM
blumpfish's Avatar
Default Re: 1500$ What to do? (blumpfish)
oh , forgot to mention, i bought it from this guy that was totally clueless, he bought it with the swap already in it.. he didnt know what was done to it at all, it has cam gears and a fuel rail, with no fuel pressure regulater, so im thinking i definately need to get one..
it might have cams if it has cam gears, but from the looks of it, it was just for show
Old May 4, 2006 | 05:11 AM
JUN.'s Avatar
maybe a set of cams ? or a turbo setup
Old May 4, 2006 | 05:29 AM
STREETWERKZ's Avatar
Default Re: 1500$ What to do? (JUN.)
look for a used supercharger kit. you'll love it!
Old May 4, 2006 | 06:27 AM
slow1990crx's Avatar
budget boost it
Old May 4, 2006 | 07:48 AM
blumpfish's Avatar
Default Re: 1500$ What to do? (slow1990crx)
my goal is to get it to run low 14s, thats not crazytalk? .. it is equally fast as my friends stock ep3, ok maybe a little tiny bit faster..
it should be in the 14s anyway.. with me in it weighs 2120
supercharger is an excellent idea, i really need to check the health of my motor before i think about going FI though, because im not sure how healthy it is really..
Old May 4, 2006 | 07:54 AM
91civichbstd's Avatar
do you do your own work
Old May 4, 2006 | 07:57 AM
crxnj's Avatar
Default Re: 1500$ What to do? (91civichbstd)
you can put together a turbokit with good parts for $1500..
by the way if you cant hit 14s with that engine in that car theres something wrong,,wether it be driver or mechanicals....i hit low 14s all day on azenis tires with a bone stock b16a engine in a heavy *** 89 si,,and you have a 88..
Old May 4, 2006 | 08:09 AM
DjChuckey's Avatar
Default Re: 1500$ What to do? (Mr.speaker)
what parts are good to build a kit for about 1,500. cuz i to want to get a turbo for my B16a....but i really dont know much about turbos...or what parts are good..for about that price... $1000 -$2000
Old May 4, 2006 | 08:15 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: 1500$ What to do? (DjChuckey)
changing to a 1.8L block what + work needed if any.
small set of cams ITR or CTR.
catback
decent header like spark racing.
That will make it better all around and better for later mods.
Old May 4, 2006 | 08:19 AM
blumpfish's Avatar
Default Re: 1500$ What to do? (***-assin)
I try to do my own work, but in reality, i dont have teh mechanical skills to do most things. ive done small things like put on exhaust, and coilovers one time.. and thats about it that i can think of.. soo yes if its easy
Old May 4, 2006 | 08:22 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blumpfish &raquo;</TD></TR><TR><TD CLASS="quote">I try to do my own work, but in reality, i dont have teh mechanical skills to do most things. ive done small things like put on exhaust, and coilovers one time.. and thats about it that i can think of.. soo yes if its easy </TD></TR></TABLE>
probbly rule out the cams and 1.8L block then, sadly they would be the biggest gainers.
catback will be arpox 200-500.
while header is 500 i beilve shipped right now as well.
other 500 i'd put away untill you know what to do. I'd say set of rims or lower it.
A header like spark will have quick and good resale so even if you do go F/I it'll be a worth while upgrade for the time you still are n/a.
sabretooth_22901's Avatar
id fix any problems with your car first double check if not triple check then i would go exhaust header all the way back new . fuel pressure reg me personally i love curves i would fix the suspension and then with what ever left id upgrade brakes but thats just me nothing better than getting a good car running perfect
Old May 4, 2006 | 08:23 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjChuckey &raquo;</TD></TR><TR><TD CLASS="quote">what parts are good to build a kit for about 1,500. cuz i to want to get a turbo for my B16a....but i really dont know much about turbos...or what parts are good..for about that price... $1000 -$2000
fuel management is free (bre or turboedit)
you can get dsm 450 injectors dirt cheap (~$50)
get a fuel pump from a dohc vtec car (-$50)
rebuilt garrett or turbonetics t3/t4 (~$350-$400)
cc-fab.net for manifold,downpipe..he stopped taking orders right now though cuz he has alot of orders and its only 1 guy..
any $30 blow off valve off ebay will do
for wastegates i only trust tial or turbosmart,,
for intercooler piping dirt cheap,, here http://store.racing-solutions.org/bendkits.html
ebay intercooler
then you'll need the miscalaneous fittings,oil lines,couplers,clamp,boost gauge,,,and you'll have to get the ecu tuned..
blumpfish's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
by the way if you cant hit 14s with that engine in that car theres something wrong,,wether it be driver or mechanicals....i hit low 14s all day on azenis tires with a bone stock b16a engine in a heavy *** 89 si,,and you have a 88..</TD></TR></TABLE>
i know it should be able to.. it feels like it runs perfectly no codes , idle at 650 smooth as hell, cracks vtec, pulls hardest around 6k, but then power falls off alot after 7.5, it seems to decrease after 6700-7000 to redline
I dont think its the driving, me and my friend went quite a few times from a roll, i could pull on him at all we were dead even almost everytime, and that thing is probably high 15s at best...
im going to put on a test pipe as soon as it gets here and im hoping a bad cat is the culprit, i also need to find a FPR, used preferably.. if anyone has one pm me.
Modified by blumpfish at 10:38 AM 5/4/2006
Old May 4, 2006 | 08:31 AM
DjChuckey's Avatar
SWEET!!!..
Old May 4, 2006 | 08:32 AM
crxnj's Avatar
yeah it could be a bad cat,,that would make sense if the power is falling off how you say..
Old May 4, 2006 | 08:37 AM
CRX Toad's Avatar
$1500 invest is and leave the car as it is.
Old May 4, 2006 | 08:50 AM
stockbee's Avatar
I realize you're wanting a faster car and all, but entertain this thought for a moment. Replace all your old and rotted suspension bushings if they aren't already. This wouldn't take all of the money you have saved up and you could do something else with the rest later.
Just think, a 88 car that drives and handles bumps in the road like new again. This is something I need to go but I just haven't got around to yet, My front end is soooo lose.
Old May 4, 2006 | 09:28 AM
crxluv2's Avatar
Default Re: 1500$ What to do? (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">$1500 invest is and leave the car as it is. </TD></TR></TABLE>
If you have to spend $$$
-dyno tune professionaly (get an adjustable FPR)
-fix rust/body damage
-replace suspension bushings
-replace faded trim/plastic parts
Old May 4, 2006 | 10:53 AM
stockbee's Avatar
I must disagree with the bottom post as far as dyno tuning a stock b16a. there's almost no point in it. you're still going to have a potential high 13 second car. Get bolt ons and go from there with tuning and so forth.
Fix that rust though for sure.
Old May 4, 2006 | 10:56 AM
DA-nteg's Avatar
test pipe
Old May 4, 2006 | 01:28 PM
pappaj's Avatar
running rich eh!, I couldnt help but notice you said there is no fuel pressure regulator, that would be a good place to start for the runnin rich prob.
BlackLudeSi
Sep 8, 2005 07:45 AM
deadly_sleeper
Jul 22, 2005 04:35 PM
Dr Doom
Apr 19, 2004 02:55 PM
gribbs
Apr 11, 2003 03:53 PM
Driven
Mar 12, 2003 02:10 PM
