need help on 89 crx starter relay????
hey guys, maybe you guys would know where can i find the starter relay for 89 crx. It all started yesterday when I started the car and drove to cosco. when I tried to start the car it won't start at all. no click no nothing at all. I thought it was the starter so i replace it and still the same no click no nothing at all. I got all power, I could here fuel pump running. I checked the fuse and it's okay. Is there a thing call starter relay? and where can i find this starter relay on my 89 crx?
Have you checked to make sure it's not just the clutch interlock switch, located high on clutch peddle arm, a common problem is the plastic "tab" the pushes against interlock switches "pin" will brake or fall out so interlock switch no longer works, unplug switch install a jumper wire until you can fix "tab".
94
94
i am currently having the same issue with my 89 hatch and i installed the jumper and same problem i can hear the fuel pump kicking on i figure its either the starter relay or starter its self but im having trouble finding the relay a picture or anything would be real helpful
Black R
Apr 8, 2023 07:14 AM
91tegrals
Feb 12, 2012 09:03 PM
CamaroKilla
15
Feb 18, 2010 10:57 AM
