don't hear fuel pump when key is "ON" position, won't start.
Old May 4, 2006 | 12:03 AM
c for sea's Avatar
Default don't hear fuel pump when key is "ON" position, won't start.
i have a 95 cx hatch. my trouble is that i can't start the car. you know when you turn the key to the "on" position and the CEL will show as you hear your fuel pump then the CEL disappears right when you hear the relay "click."
well, i stopped for gas. when i went to turn the car on and had the key in the "ON" position, i don't hear my fuel pump. the CEL still appears but doesn't go away. so obviously i don't get to the part where the relay clicks. the car will crank. i just ain't getting any fuel. any ideas? thanks in advance.
Modified by c for sea at 9:14 AM 5/4/2006
Old May 4, 2006 | 12:12 AM
honda_civic1's Avatar
well if you dont hear the fuel pum relay click after you turn the car to on position then its a a bad fuel pump relay replace it.
Old May 4, 2006 | 04:16 PM
c for sea's Avatar
anybody know what the regular 30a fuse is for under the hood? it's the only one. in the corner of the fusebox (EG's)
RecklessEJ
15
Sep 18, 2011 03:56 PM
whitehf
Aug 6, 2006 01:22 PM
nicehatchy
Mar 5, 2006 06:57 PM
XzzYzzX
Jul 31, 2004 08:13 AM
shoebox
Feb 11, 2004 11:18 AM
