What tire size to use with 15x7 rims? 215/45/15s?
Old May 3, 2006 | 11:41 PM
dt4life's Avatar
Default What tire size to use with 15x7 rims? 215/45/15s?
What tire sizes to you recommed for 15x7 for a DC2? I was really hoping to run wider then 205s. I'ver heard of a few running 215s and 225s. I was looking at the 215/45/15 Toyo T1S's but was curious what others had to say. Any and all suggestions are welcomed. Thanks!
Old May 3, 2006 | 11:44 PM
Crackerballer's Avatar
I think 215 it is. Whatever tire rack recommends, normally u can go a size, maybe 2, wider. Problem is, certain tire companies vary their tire sizes such that one set of 215's may work great and other may rub.
Old May 4, 2006 | 08:24 AM
dt4life's Avatar
Default Re: What tire size to use with 15x7 rims? 215/45/15s? (wannaTypeR)
has anyone else ran these? I'm trying o get the most tire contact possible w/out rubbing
Old May 4, 2006 | 08:31 AM
Lan's Avatar
Lan
I would recommend you listen to nsxtasy. He always says get a better tire not wider. I wanted wider tires too but I am getting some today that have a lot more traction than my current falkens.
Old May 4, 2006 | 08:54 AM
1337whp's Avatar
Default Re: What tire size to use with 15x7 rims? 215/45/15s? (Lan)
ive ran 215/45 /16 on my fronts and liked em, theyd prolly look nice on 15s if your slammed
edit: dunlop sports pwn btw
Old May 4, 2006 | 09:56 AM
dt4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend you listen to nsxtasy. He always says get a better tire not wider. I wanted wider tires too but I am getting some today that have a lot more traction than my current falkens. </TD></TR></TABLE>
Great advice. If I was to get 205/50/15s would you recommend Bridgestone S-03s, Toyo T1Ss, or Yokohama ES100s.
Old May 4, 2006 | 10:01 AM
Lan's Avatar
Lan
I just received 205/40/17 for my volks. Bridgestone Potenza RE750 $52 dollars at http://www.tirerack.com !!! They are very well rated . I am very pleased with tirerack! I ordered the tires, and got them today! Less than 48 hours!
Old May 4, 2006 | 11:13 AM
sirg-vtec's Avatar
I'll fill in for nsxtasy.
205/50/15 is the tire closes to the factory specs. Wider is not always better.
Also, what do you want out of the tire? Performace? Longevity?
A good tire is the Goodyear Eagle F1 GS-D3. But they only come in 195/50/15 for 15 in. only.
Falken Azenis are superb in dry traction but suck in wet and doesn't last long.
Yoko es100 are a good budget tire for the wet/dry.
It all depends on what you want and what do you need it for.
Old May 4, 2006 | 11:23 AM
dt4life's Avatar
Default Re: What tire size to use with 15x7 rims? 215/45/15s? (sirg-vtec)
I'm looking for great grip in all weather because it rains all time here in WA. My main focus for the car is handling, if I can get better traction/handling out of the 215/45/15s then but Iwasn't sure.
Old May 4, 2006 | 01:16 PM
Just_LS's Avatar
I'm running S-03 on mine and I can tell you the wet streets we have in the NW is a non-issue for the tire.
Old May 4, 2006 | 01:18 PM
dt4life's Avatar
Default Re: What tire size to use with 15x7 rims? 215/45/15s? (Just_LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just_LS &raquo;</TD></TR><TR><TD CLASS="quote">I'm running S-03 on mine and I can tell you the wet streets we have in the NW is a non-issue for the tire.</TD></TR></TABLE>
very nice! what size are you using on what rims?
Old May 4, 2006 | 01:19 PM
Lan's Avatar
Lan
http://www.tirerack.com/tires/...RE750 - these are the ones I got
Old May 4, 2006 | 01:38 PM
Just_LS's Avatar
195/50-15 on 15 x 7. I'm a cheap bastard to get 205/50-15. After this set is done I probably will swith to Goodyear F1 since the S-03 is a lot more expensive now
DA9Sleeper
Jan 26, 2010 01:29 AM
Rooftop voter
May 21, 2009 05:10 AM
realis9
Jul 9, 2007 09:30 AM
DuVaL rAcEr
Apr 20, 2006 04:08 AM
kickdown
Oct 29, 2001 12:06 PM
