Why is this person so convinced STD axels with work with a B16, anyone actually try it?
Old May 3, 2006 | 10:45 PM
O16581724 5 2 5's Avatar
Default Why is this person so convinced STD axels with work with a B16, anyone actually try it?
I posted this in my other thread, but i'm making another dedicated to just this, i'm wondering if anyone has actually tried their stock STD/HF Axels and failed, this person seems convincing that they've swapped no problem.
O16581724 5 2 5: The axels and shift linkage won't work i found out.
: yeah they will
O16581724 5 2 5: I was almost positive they wouldn;t.
O16581724 5 2 5: I posted up on Honda-Tech to check.
: ive worked on enough Hondas in my day t oknow
O16581724 5 2 5: I don't know, i'm real drunk ATM.
: what the hell?|
O16581724 5 2 5: They're telling me on H-T it won't work with stock axels and shift linkages. =\
: well they lied to you
: come over and ill prove it
: tell whoever told you that its pretty sad that a GIRL knows more then them about Hondas
If STD axels won't work, what is the reason?
Old May 3, 2006 | 11:05 PM
31flavorscivic's Avatar
Default Re: Why is this person so convinced STD axels with work with a B16, anyone actually try it? (O165817
my ZC tranny used 90-93 teg axles, and I put a std. axle in there and the shaft was WAY too small. It was not even close.
Old May 3, 2006 | 11:19 PM
Maybe this person is thinking an STD is a DX then...
Old May 3, 2006 | 11:45 PM
SD_Lurker's Avatar
HT White Ops
NO IT WILL NOT WORK AND THATS THE BOTTOM LINE. There is no reason to argue this matter. There is not a single doubt in my mind that 88-91 STD or Si axles will not work with a b-series engine. The b-series engines use a mid-shaft and the STD or Si uses one long axle. If this dumb *** girl wants to believe that they will work, then let her.
Old May 3, 2006 | 11:46 PM
SD_Lurker's Avatar
HT White Ops
A STD is a DX. What are you talking about?
Old May 4, 2006 | 04:54 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">A STD is a DX. What are you talking about?</TD></TR></TABLE>
suure it is..
in a crx maybe.. CRX DX (aka Std).
but not for a civic.
Civic Std = 4spd crap
Civic DX = 5spd less crap
and every1 here is right the D-series axles for our USDM cars are too small for the bseries diff.
Old May 4, 2006 | 05:40 AM
Jesterian's Avatar
24.243.141.75
Geez dude, try to know what you're talking about. Std = standard.
Old May 4, 2006 | 08:54 AM
SD_Lurker's Avatar
HT White Ops
Let me ask you this. When is the last time you looked at the Models for civic/crx's??? There are Si, HF, and DX. I dont think I ever heard of a STD. when people say STD they are refering to DX's
Old May 4, 2006 | 09:01 AM
4gencivicef9's Avatar
yo the splines are different, I swaped a b series into a dx (standard) the dx is considered the the std......the only hubs that will work for a zc swap or b series swap is si ones.......I had to get integra hubs for the swap.........
Old May 4, 2006 | 09:10 AM
gnar kill's Avatar
whoever says they knew **** about anything and that STD axels will work with a b16 is dumber than what I flush down the toilet.....there is a reason why people =put SI knuckels on there STDs when switching to a b16 or even a d16 the spline counts are different......
Old May 4, 2006 | 10:07 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">Let me ask you this. When is the last time you looked at the Models for civic/crx's??? There are Si, HF, and DX. I dont think I ever heard of a STD. when people say STD they are refering to DX's</TD></TR></TABLE>
for civic hatch there is si,dx,and std..std being the lowest one that comes 4spd manual and vinyl seats,,no passenger side mirror standard,etc...
and then for crx its si,hf,std...but most people refer to and know the std crx as a dx,,but if you look in manuals for our cars or brochures or whatever its says std crx..
and i dont know why that person thinks the stock d-series linkage and axles will work for the b-series swap...??????
Old May 4, 2006 | 10:15 AM
They're also selling a B16 with transmission, ECU, and harness for $300, so i'll let them continue being stupid.
Unless they're somehow confusing a B16 with a D16?
Old May 4, 2006 | 10:27 AM
Jesterian's Avatar
24.243.141.75
Look at my signature. I drive a civic std. You lose?
Old May 4, 2006 | 10:53 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 &raquo;</TD></TR><TR><TD CLASS="quote">They're also selling a B16 with transmission, ECU, and harness for $300, so i'll let them continue being stupid.
Unless they're somehow confusing a B16 with a D16?</TD></TR></TABLE>
yeah thats possible,its happens all the time...because a complete b16a swap for $300 is pretty unreal,, even the stolen b16 swaps here in NJ go for around $700 complete...better confirm the engine.
Old May 4, 2006 | 10:59 AM
They said "B16A", it's in a totaled 97 Hatchback. Even if it's a D16 VTEC, it's a good deal for $300 with ECU, harness, Engine and Tranny.
Old May 4, 2006 | 11:21 AM
charliev's Avatar
hmmmmmm........NOO
DX has 5spd
STD has 4spd
DX has front sway bar and no rear
STD has none
i think there was a STD model you just didnt realize it buddy!!
Old May 4, 2006 | 11:23 AM
Jesterian's Avatar
24.243.141.75
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charliev &raquo;</TD></TR><TR><TD CLASS="quote">
hmmmmmm........NOO
DX has 5spd
STD has 4spd
STD has none
i think there was a STD model you just didnt realize it buddy!! </TD></TR></TABLE>
I should invest in some sway bars!
Old May 4, 2006 | 11:27 AM
STD has no badge, black finish piece between the lights, vinyl interior, no carpet in the door panels, nothing around the shifter, no hubcaps, 70hp, smaller axles(?). Quite a bit seperates it from the DX...
Old May 4, 2006 | 12:53 PM
Jesterian's Avatar
24.243.141.75
Uh it actually has a crappy shift boot. Unless the one in my car is aftermarket.
Old May 4, 2006 | 01:08 PM
Well, yeah, shift boot, but no plastic surround.
Old May 4, 2006 | 03:05 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Whether it was a Civic STD or CRX DX,The axles won't work..
You may be able to shove them into the transmission,
But that doesn't mean they will drive the car..
On the left a DX passenger side axle that came from my car,
On the right an Integra axle that came with my swap.
Measurements are width of race and splined drive area;
Axles on the outsides are stock CRX DX,Inside two axles came with B16:
On the linkage,the ends are different,as well as the length of both rods;
Stock on top,B16/Integra style below it:
B16 linkage is on the outsides, 2 Stock linkages in the middle:
Modified by 88DXCRX at 6:28 PM 5/4/2006
Old May 4, 2006 | 03:25 PM
Crx Jimmy's Avatar
^not true , i have one of each (std and dx) the std has a 4spd, no rear wiper, no intermittant wipers, no tilt column, no ac, no rear washer squirter, there IS a big difference, on my title one says civic DX and one says STD
Old May 4, 2006 | 03:28 PM
crxnj's Avatar
my std came with a/c..and original price sticker,,its seems that a/c option was +$2000...
thanks 88dxcrx for those pics..link the seller to this site so he/she can see these pics
Old May 4, 2006 | 03:35 PM
SD_Lurker's Avatar
HT White Ops
I always thought that when people said STD they were refering to their DX. Its not that big of a ******* deal.
Old May 4, 2006 | 03:51 PM
Import Al's Avatar
No its no BFD, but I spent about a year finding a mint 91 STD just to save 55 pounds over a DX before even gutting it.
The one thing I envy from DX/Si's are the stronger drivelines & 5 speed trannies, but I like not having a rear wiper, badging, a sunroof, P/S etc without ripping **** apart.
Now just to build my swaybar-less suspension...
