Shimming an oil pump... How much is too much?
Old May 3, 2006 | 09:53 PM
Circuit Star-29's Avatar
Default Shimming an oil pump... How much is too much?
Just curious on what would be a "max" on shimming an oil pump...How thick of a washer is too thick? Looking for those w/ experience.
Old May 4, 2006 | 09:40 AM
RagingAngel's Avatar
Default Re: Shimming an oil pump... How much is too much? (Circuit Star-29)
don't shim it....
most people confuse pressure with flow.
More pressure does not equate more flow in this case.
You want more flow and shimming the pump does not give you that.
Try porting the pump instead....
Old May 4, 2006 | 09:43 AM
Default Re: Shimming an oil pump... How much is too much? (RagingAngel)
I had considered this but porting would reduce pressure wouldn't it?
So, IMH it would seem reasonable to port the pump and shim the spring...Right?
Old May 4, 2006 | 09:51 AM
Unless you intend to hog out the pump, the added flow you gain is not going to drop the pressure to a detrimental state.
I might consider shimming after porting if I was running an external oil cooler....but even those with this exact setup have not starved their motors or experienced excessive or even noticeably less pressure.
Just put the motor back together....
Old May 4, 2006 | 09:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
Just put the motor back together.... </TD></TR></TABLE>
its trying to come together...keep hitting roadblocks the size of a 747...
Old May 4, 2006 | 11:37 AM
RTW DC2R's Avatar
Ive never heard of this. Why are you trying to do this, what is it supposed to accomplish, and how do you actually go about doing it?
What does porting the pump housing accomplish?
Old May 4, 2006 | 11:44 AM
92TypeR's Avatar
FSAE
Default Re: (clip the apex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clip the apex &raquo;</TD></TR><TR><TD CLASS="quote">Ive never heard of this. Why are you trying to do this, what is it supposed to accomplish, and how do you actually go about doing it?
What does porting the pump housing accomplish?</TD></TR></TABLE>
Adding washers at the end of the pressure releif valve increases maximum pressure before the valve opens. Some believe the increase in oil pressure is beneficial, I've seen no proof of this being the case.
Porting the actual pump allows for a larger volume of oil to circulate for every revolution of the pump gear, thus more volume flow. However, when you increase volume, relative pressure drops, so compensating by shimming the pressure relief valve is one way to counteract the drop in pressure. The only problem with this is that the pressure relief valve determines maximum pressure only, and does not compensate for the slightly lower % of pressure at lower RPM's/load.
Cliff notes - Don't waste your time with shimming the oil pump.
Badassbigblock
Feb 17, 2018 01:19 PM
hahaha38
Jan 29, 2008 02:51 PM
hany
Oct 5, 2006 05:20 PM
ham
Nov 23, 2005 06:06 PM
