tranny grinds....no bueno
Old Apr 9, 2002 | 07:24 PM
Kazmans94cord's Avatar
Default tranny grinds....no bueno
ok if i shift to 2nd after about 4500 rpms it grinds hella loud...and sometimes it doesnt go in to reverse and when it finally does it grinds...does this mean the tranny is givin out or what? im not sure when the last time the tranny fluid was changed...
Old Apr 9, 2002 | 07:26 PM
Nick H's Avatar
New User
Default Re: tranny grinds....no bueno (kazmans94cord)
auto or manny?
Old Apr 9, 2002 | 07:30 PM
John's Avatar
New User
reverse always grinds a bit...
Old Apr 9, 2002 | 07:33 PM
Default Re: tranny grinds....no bueno (nickh2k1)
manny....
ya i know it usually grinds...but i mean it sometimes wont even go into reverse you gotta really throw it in there and when it does go in it grinds..
Old Apr 9, 2002 | 07:34 PM
Nick H's Avatar
New User
Default Re: tranny grinds....no bueno (DunReit)
alright...i'm guessing it's a manny since you said that you shift to second...(unless you are one of those wanna be manual's that shift their auto's)...this could be a result of this transmission fluid being low...but you can check that easily...if it's not that then i don't really know what to tell you...
Old Apr 9, 2002 | 07:35 PM
ok yeah this is a really stupid question..but ive been wanting to change out the tranny fluid for a while..but not sure how...how do i go about doin this?
Old Apr 9, 2002 | 07:37 PM
John's Avatar
New User
manny....
When the car doesn't want to go into reverse (or any gear), don't force it. For reverse, I'll sometimes put the car in 1st gear, and then in reverse, and it goes in smoother (for some odd reason that I can't explain).
Old Apr 9, 2002 | 07:38 PM
Accord94DX's Avatar
manny....
Check your owners manual, they actually recommend you put it in first then reverse.
Old Apr 9, 2002 | 07:39 PM
thanks for the advise...i got a question tho...whats holding it back from goin into gear...or are there several reasons why?
Old Apr 9, 2002 | 07:41 PM
CmptchAV6's Avatar
I think it has to do with the teeth on the gears not being lined up
On a manual transmission there are little forks that lockup the gear that you are using. If the for isnt lined up then it wont go in. Fluid helps but reverse tends to have less teeth than the other gears making it harder to go into. This is just an assumption going on what I have learned off of http://www.howstuffworks.com
Nick H's Avatar
New User
have a transmission specialist do it for you...you have to remove the transmission itself and then it has to be resealed afterwards...it costs about $150 to have done but if it needs to be done it needs to be done!
[Modified by nickh2k1, 11:42 PM 4/9/2002]
Old Apr 9, 2002 | 07:43 PM
Accord94DX's Avatar
Um. Negative homeboy. Its two 17mm bolts right by the CV joint.
Old Apr 9, 2002 | 07:46 PM
Nick H's Avatar
New User
Default Re: tranny grinds....no bueno (Accord94DX)
are you serious? i thought the transmission had to be romoved to drain the fluid?...****...i got ripped off!!!! ...again feeling stupid!
Old Apr 9, 2002 | 07:47 PM
Accord94DX's Avatar
Holy ****!! You got it up the ***! We charge 30 bucks at honda for the change!!
Old Apr 9, 2002 | 07:50 PM
CmptchAV6's Avatar
what place did this to you???? Sounds like a buyer beware to me.
Old Apr 9, 2002 | 07:55 PM
is this where i drain it? and where do i refill it?
or should i take it to the dealer ?
[Modified by kazmans94cord, 10:56 PM 4/9/2002]
Old Apr 9, 2002 | 07:59 PM
CmptchAV6's Avatar
one 17mm bolt is to drain the other is to fill. Make sure you get a funnel that can bend the fill hole is typically sideways from what I have seen.
Old Apr 9, 2002 | 08:00 PM
brawl's Avatar
I'm not sure if its with all other transmissions, but on 4th gens, there's 2 small bolts (17 mm sounds about right) on the bottom of the transmission right to the upper left of the CV boot. The lowest one is where you check the fluid. the one that is the next bolt up clockwise is the fill bolt. its pretty easy to see but it can be a pain in the butt to fill.
Old Apr 9, 2002 | 08:01 PM
Default Re: tranny grinds....no bueno (CmptchAV6)
hmm..thats odd...how many qts. are in a bottle..and how many would i need?
Brandon's Avatar
Life is Suffering
This may not apply to you, but I had a bad clutch slave cylinder (a Honda weakpoint) which leaked fluid slowly enough that after a while, the clutch would not engage fully and would make a grinding noise while shifting.
Old Apr 9, 2002 | 08:02 PM
im guessin yall also serve turkey and cheddar or peanut butter jelly sammiches?
Old Apr 9, 2002 | 08:03 PM
Default Re: tranny grinds....no bueno (vtec2k2)
dude i hope that doesnt apply to me...
Old Apr 9, 2002 | 08:06 PM
Brandon's Avatar
Life is Suffering
It's a pretty easy fix, but the slave cylinder costs about 50 bucks.
CmptchAV6's Avatar
depends on the engine and tranny. I dont know how much fluid the manual transmission requires either although someone else here should
Old Apr 9, 2002 | 08:16 PM
smokin rubber's Avatar
I think all the manual trannies hold two qt, I bought a funnel with a large bendy extension on it, I could probably change the fluid in less than fiveteen min.
