timing belt
Old May 3, 2006 | 06:13 PM
jccigt's Avatar
Default timing belt
hey im new to the forum wondering if anyone can answer this for me. my freind has a 94 prelude w/ an h23 motor non v-tec and the other day he snapped his timing belt. He wants me to do the job and i keep telling him its an interference motor and he most likely bent a valve and he should just buy a new head but he wants me to do the timing belt anyways. i was wondering if its 100% that he bent a valve and if not is there any test i can run just to make sure. i dont feel like doing the timeing and not have it start and do it all over again
Old May 3, 2006 | 06:28 PM
twistedbydezign's Avatar
Default Re: timing belt (jccigt)
compression test should tell you
Old May 3, 2006 | 06:38 PM
jccigt's Avatar
Default Re: timing belt (twistedbydezign)
so theres a possibilty nothings bent?
InvaderTrax's Avatar
But he can't do a compression test without a properly installed timing belt. Otherwise he will definitely bend a valve
Old May 3, 2006 | 07:05 PM
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">But he can't do a compression test without a properly installed timing belt. Otherwise he will definitely bend a valve</TD></TR></TABLE>
haha duh....either convince the guy he needs a valve job (probably does anyways being 11+ years old, or remove the the upper timing belt cover, and rotate the cams and crank by hand (making very sure that you are rotating them so that the cams and crank are turning with the same cylinder at TDC), then do a leakdown test while each cylinder is at TDC
Old May 3, 2006 | 07:53 PM
SKDRCR's Avatar
Default Re: (twistedbydezign)
how fast was he going when it broke?
Old May 3, 2006 | 09:00 PM
Hawkze_2.3's Avatar
90% chance of bent valves....they can be bent so minutely that you can't see it with your naked eye, but a machine shop can tell you. I bent all of my valves when my TB slipped.
Old May 4, 2006 | 06:39 AM
TruNinja619's Avatar
Default Re: timing belt (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jccigt &raquo;</TD></TR><TR><TD CLASS="quote">hey im new to the forum wondering if anyone can answer this for me. my freind has a 94 prelude w/ an h23 motor non v-tec and the other day he snapped his timing belt. He wants me to do the job and i keep telling him its an interference motor and he most likely bent a valve and he should just buy a new head but he wants me to do the timing belt anyways. i was wondering if its 100% that he bent a valve and if not is there any test i can run just to make sure. i dont feel like doing the timeing and not have it start and do it all over again</TD></TR></TABLE>
if you can't convince him that he has bent valves b/c he snapped his timing belt.. then I suggest that you don't do the work.. b/c you're basically wasting your time changing it...
Old May 4, 2006 | 02:37 PM
jdmnash's Avatar
Default Re: timing belt (TruNinja619)
i was going 28mph when my timing belt went in my h23a1 and i bent valves all to fu**. new motor now. i still have pics if u want proof.
Old May 11, 2006 | 10:33 AM
reAper86's Avatar
the valves cant be bent
just replaced the timing belt thats all
Old May 11, 2006 | 10:53 AM
Default Re: timing belt (reAper86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reAper86 &raquo;</TD></TR><TR><TD CLASS="quote">the valves cant be bent
just replaced the timing belt thats all</TD></TR></TABLE>
why would u think the valves wouldnt be bent???
Old May 11, 2006 | 01:45 PM
Chuckles99SH's Avatar
Please explain your infinate knowledge of honda motors to the rest of us. I would love to hear it, chances are that if you snap a timing belt or have it slip, have your tensioner fail you are going to bend some valves. You could even have piston damage because your pistons would be the ones closing the valves for you. Example, your timing belt snaps when your exhaust valves are open, they are not going to close on their own, along comes a piston and bingo your valves are closed now.. and you have some repair work ahead of you ie all your exhaust valves and possibally your pistons.
Old May 11, 2006 | 08:07 PM
Silver Surfer's Avatar
mine snaped in 4th gear at 1000rps, nothing bent...got lucky
Old May 11, 2006 | 09:19 PM
Default Re: (Silver Surfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver Surfer &raquo;</TD></TR><TR><TD CLASS="quote">mine snaped in 4th gear at 1000rps, nothing bent...got lucky</TD></TR></TABLE>
was this confirmed by a compression test or machine shop or ...???
Old May 12, 2006 | 08:59 AM
Hawkze_2.3's Avatar
Yeah, you just need to stop posting because that's rediculous. You have no idea what is happening with his engine....you sound like some scammer mechanic who thinks he knows everything and does crappy work because you're soooooo confident that every little thought in your head is right.
bvcrv
Jan 16, 2010 05:46 PM
prcivic91
16
Mar 16, 2007 08:33 PM
RockLee`
Oct 29, 2006 03:43 PM
MISFITofMAGIC
Jan 7, 2006 08:53 PM
andlude
Sep 17, 2004 07:09 AM
