b18b1 random misfire, please help
Old May 3, 2006 | 06:07 PM
logikalfury's Avatar
Default b18b1 random misfire, please help
ok, i swapped an obd1 b18b1 into my 94 dx. im getting random misfire. but its not throwing any cel codes. ive searched for any info i could find out, but couldnt find anything with a similar issue. so heres what ive done already, and heres what happens.
random misfire at cold start, at idle, and under load. its just a random misfire al together. at cold start the engine also surges from 2k-2200rpm.
heres what ive done so far. seafoam treatment, replace dizzy cap, rotor, spark plugs, plug wires. checked fuel line from fuel filter-fuel rail.
if any1 can think of anything, lemme know im tryin to do this on my own cuz im sick of paying other ppl to TELL me my car is misfiring, and not being able to fix it.
thanks in advance,
matt
Old May 3, 2006 | 06:18 PM
E46Kid's Avatar
wow sounds real odd since u say u replaced the dizzy cap, rotor, spark plug and wires. Bump for you!
Old May 4, 2006 | 06:35 AM
bump for more help please
Old May 4, 2006 | 05:08 PM
boost'd_crx's Avatar
Default Re: b18b1 random misfire, please help (logikalfury)
check the compression
Old May 4, 2006 | 09:22 PM
RaceCarRyne's Avatar
Default Re: b18b1 random misfire, please help (boost'd_crx)
check injectors, fuel pump, fuel filter, air filter, and all grounds
Old May 6, 2006 | 08:38 AM
i talked to honda, they said it could also be a coil pack issue.
has any1 else had an issue with a coil pack going bad?
Naiyasin
Mar 8, 2011 11:27 AM
honda20crx
Apr 19, 2010 12:51 PM
egGSR_hi
May 16, 2009 12:23 PM
barkwaffle
Jun 2, 2005 10:09 AM
Master23
Aug 1, 2004 08:16 PM
