1/4 miles times in Turbo Type R.
Old May 3, 2006 | 06:07 PM
spooledex's Avatar
Default 1/4 miles times in Turbo Type R.
Well first time at the track with the Type R on 12 psi. I was sort of happy with the times other than knowing I need some slicks. First off the setup is just a 9.0:1 comp. Arias pistons and eagle rods. Car put down 313 at 10 psi with a t3/t4e 60 trim .63 a/r. Well just went there to mess around a little bit til I get the hatchback done. spinning through 1st and 2nd. Car is pretty heavy with a custom stereo system. I know the 60 foots can come down a little but had street tires on. Let me know what you think. I think high 11's is possible easy with time. This is my daily though.
60' 2.2
1/8th 8.5 @92
1/4 12.5@119
Old May 3, 2006 | 06:23 PM
BMC's Avatar
BMC
Default Re: 1/4 miles times in Turbo Type R. (spooledex)
Where did you move too man?
I wanted that teg but couldnt get a hold of you.
Good times man. I wish it could have been mine.
Old May 3, 2006 | 06:38 PM
D-tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooledex &raquo;</TD></TR><TR><TD CLASS="quote">Well first time at the track with the Type R on 12 psi. I was sort of happy with the times other than knowing I need some slicks. First off the setup is just a 9.0:1 comp. Arias pistons and eagle rods. Car put down 313 at 10 psi with a t3/t4e 60 trim .63 a/r. Well just went there to mess around a little bit til I get the hatchback done. spinning through 1st and 2nd. Car is pretty heavy with a custom stereo system. I know the 60 foots can come down a little but had street tires on. Let me know what you think. I think high 11's is possible easy with time. This is my daily though.
60' 2.2
1/8th 8.5 @92
1/4 12.5@119</TD></TR></TABLE>
turn the boost up to 15psi and give me the keys
Old May 3, 2006 | 09:12 PM
busted-B18's Avatar
wow, that is impressive. what size street tires did u have on? 15, 16, or 17?
Old May 4, 2006 | 06:21 PM
spooledex's Avatar
Default Re: (busted-B18)
Just have 15 inch azenis on for now. I will have more time to play with it since I only live 20 miles from a track now. New to Greatlakes dragway, which is totally dead up here and only had 2 other civics and no tegs at the track last time I went.
team 15
Jun 14, 2007 06:16 PM
efgarage
May 3, 2005 10:58 AM
xmilanoredsix
Jul 9, 2004 07:31 AM
g5r
Jun 14, 2003 09:12 AM
JSpecwest
Jul 23, 2001 03:03 PM
