Legit F/B 2.0L...ENGINE RACE READY!
I'm trying to see what I can get for this Motor??? Parting out is may be my last resort, before I part out I might just keep it! BUT STILL MAKE OFFERS ON WHAT YOU LIKE! N-E-Thing is possible! The motor has been assembled by Rage Performance in Upland,CA. I provided every part except pistons!<FONT COLOR="pink"> This motor has no reused parts on it except for bolts & sensors <U>Everything else is NEW</U></FONT>
<FONT SIZE="5"><FONT COLOR="red">KEEP IN MIND O MILES ON THIS SETUP!! Now asking 8.5k obo for everything!!</FONT></FONT>
You can ask for any options to fit your budget..if you don't see it hear CREATE YOUR OWN!!!
<FONT COLOR="blue"><FONT SIZE="4">B16 head</FONT></FONT>
ARP Head bolts
B&M FPR
5 angle valve job
Omni valves, springs & retainers
BC Stage IV Cams & Gold Gears
NEW Type R Vtec solenoid
Password Cam Seal
OEM valve cover
OEM Manifold w/ injectors
OEM bored over throttle body
(OPTIONAL/installed)
NEW Skunk2 Manifold
NEW RC 310cc injectors
NEW Blk D1 Vtec solenoid cover
NIB Type R valve cover
NIB Vision CF spark plug wire cover
<FONT COLOR="pink"><FONT SIZE="4">B18c1 block</FONT></FONT>
Balanced & Blueprinted
Micropolished crank
ARP Rod Bolts
Mugen oil filter
Spoon Magnetic drain plug
Custom 12:5.1 JE pistons
Scat H-Beam Rods
NEW OEM Bearings
NEW Type r Oil pump
NEW Type r Water pump
NEW Oil pick up
Gsr baffled oil pan
(OPTIONAL)
<FONT COLOR="red">***SOLD TO JUSTIN****Jun TYPE Header</FONT>
<FONT COLOR="red">***SOLD TO ~Zoso~**** Zex nitrous kit</FONT>
<FONT COLOR="orange"><FONT SIZE="4">B16A2 Trans</FONT></FONT>
New Synchros
New Seals
OEM flywheel
OEM crank
(OPTINAL/installed)
Quaife Lsd
XTD STAGE 4 Clutch
XTD 10lb. Flywheel
OEM B16A2 block
30,000 miles B- series Axles
Shift Linkage
SI Wiring Harness
b16a2 Crank
99-00 civic si SubFrame
[5] 14' blk 4x100 bmw wheels w/ tires 200 (look like sprint hart cp's)
Serious buyers call 909)728-9967/ email jdmjnky@yahoo.com
Modified by JDMJNKY at 9:29 AM 5/13/2006
Modified by JDMJNKY at 1:30 PM 5/18/2006
Modified by JDMJNKY at 1:31 PM 5/18/2006
Modified by JDMJNKY at 1:32 PM 5/18/2006
Modified by JDMJNKY at 1:33 PM 5/18/2006
Modified by JDMJNKY at 8:12 PM 5/24/2006
Modified by JDMJNKY at 8:14 PM 5/24/2006
ARP Head bolts
B&M FPR
5 angle valve job
Password Cam Seal
OEM valve cover
NEW Skunk2 Manifold
Micropolished crank
ARP Rod Bolts
Mugen oil filter
Scat H-Beam Rods
NEW OEM Bearings
NEW Type r Oil pump
NEW Oil pick up
Gsr baffled oil pan
(OPTIONAL)
New Synchros
New Seals
OEM flywheel
OEM crank
(OPTINAL/installed)
Quaife Lsd
XTD STAGE 4 Clutch
XTD 10lb. Flywheel
OEM B16A2 block
Shift Linkage
SI Wiring Harness
b16a2 Crank
