CEL Code #1 on EG B16A WTF..........?
Old May 3, 2006 | 05:05 PM
dohctor_B's Avatar
Default CEL Code #1 on EG B16A WTF..........?
Here's the story. My CEL will come on one day when i'm driving to school, then it will go away and not come back for another week. And now its been coming on like everyday so far.
Here's the problem: I know that CEL #1 is the Oxygen sensor, but <U>i just replaced it 5 months ago with a brand new one</U>! What other possible issues could there be to fix this? -- car is a 94 civic EX with a JDM B16A and a chipped and tunned P28 ECU(if that mattters at all). thanx
Old May 3, 2006 | 05:58 PM
egsleepercivic's Avatar
well if you know the O2 is good, then its either physically the wires( may be frayed etc.) or the ecu is bad.
personally I would trace the wires from the O2 to the ecu and make sure there are no cut slices wear marks anything
good luck
Old May 3, 2006 | 06:41 PM
tempsohc's Avatar
well it could also be because you have a aftermarket fpr...and its throwing off the air/fuel and fowling the o2 quickly if you have a chipped computer or cams ,vtec controller,Fuel pressure regulator...and its not tuned correctly this will happen
Old May 3, 2006 | 06:42 PM
dohctor_B's Avatar
Default Re: (egsleepercivic)
thanx for the advise, bump for some more
Old May 3, 2006 | 08:37 PM
jdeemseerx's Avatar
if it comes on intermittently i would have to say bad wiring or the wire is rubbing on something possible? maybe a bad connection at the pin.. check those out you can also check the voltage that the sensor is putting out
Old May 4, 2006 | 06:32 AM
dohctor_B's Avatar
Default Re: (jdeemseerx)
i'll have to check the wires out, see if they're loose or frayed. Any other advise?
Vomit
Nov 20, 2013 08:24 PM
EF-8SiR
12
Feb 13, 2011 07:16 PM
z6htch
Aug 1, 2009 10:56 AM
silverCRXTC
Jun 3, 2003 06:50 PM
senpai
Jan 12, 2003 12:36 PM
