Help.. Car Started.. and now it doesnt... ECU problem maybe?? HELP..
Old May 3, 2006 | 03:52 PM
DeviousCTR's Avatar
Default Help.. Car Started.. and now it doesnt... ECU problem maybe?? HELP..
ok fellas.. i finished my swap and last nite i fired it up and it started.. drove it home.. then this morning i tried to start it.. it didnt start up.. my ecu is making a funnny noise.. im running my stock 2000 ex ecu- the motor swap a 95 LS.. could it be a crank sensor or immoblizer?? this is pissing me off.. im thinking its my ecu.. i tried starting it all day today.. sometimes it start then dies out immediately.. HELP HTers.. THANX
Old May 3, 2006 | 04:53 PM
spoonracer84eg's Avatar
Default Re: Help.. Car Started.. and now it doesnt... ECU problem maybe?? HELP.. (DeviousCTR)
Do you have a obd1 to obd2 harness. Not sure but that could be why your car is messed up. You definately need to get the correct ecu.
Old May 3, 2006 | 06:22 PM
DeviousCTR's Avatar
my ecu makes funny noises.. could that be why it wont start? it started up fine before.. i know i should get the rite ecu... but shoulndt it still start?
Old May 3, 2006 | 09:04 PM
DeviousCTR's Avatar
help
Old May 3, 2006 | 11:17 PM
DeviousCTR's Avatar
up..
Old May 4, 2006 | 12:58 AM
honda_civic1's Avatar
dude first of why the hell are you using a obd2 civic sohc vtec ecu on a 95 obd1 dohc non-vtec motor swap??, you have to get the right wire harness from a obd1 92-95 LS and ECU. that the problem right there. plus ecu's don't make noise's, so thats just probably your fuel pump relay.
Old May 4, 2006 | 01:06 AM
DeviousCTR's Avatar
Default Re: (honda_civic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_civic1 &raquo;</TD></TR><TR><TD CLASS="quote">dude first of why the hell are you using a obd2 civic sohc vtec ecu on a 95 obd1 dohc non-vtec motor swap??, you have to get the right wire harness from a obd1 92-95 LS and ECU. that the problem right there. plus ecu's don't make noise's, so thats just probably your fuel pump relay. </TD></TR></TABLE>
trust me the ecu makes a clicking noise.. its hard to explain..
DeviousCTR's Avatar
trust me the ecu makes a clicking noise.. its hard to explain.. i know there nothing wrong with the ecu tho..
Old May 4, 2006 | 01:08 AM
DeviousCTR's Avatar
its hard to explain.. when the click the ignition to on i can hear the fuel pump then its stop rite.. then i head clicking noise from the ecu... i know theres nothing wrong with the ecu.. it fines..
Old May 4, 2006 | 01:12 AM
whats that got to do with anything i never said anything about your ecu being bad, its just that your running a totally different ecu/wire harness on a complete different swap.
Old May 4, 2006 | 01:18 AM
DeviousCTR's Avatar
ive ran a non vtec ecu on a vtec motor before in my old db7 integra and it ran fine.. just never hit vtec.. so shouldnt it still work? well anywase i know i need to run the rite ecu.. just need to find someone selling the jumper harness..
Old May 4, 2006 | 01:20 AM
i just don't think/or ever heard of a ecu make sounds, but anyways good luck with everything.
Old May 4, 2006 | 01:24 AM
yeah but your talking about running a 0bd2 single cam ecu/wire harness on a obd1 dohc motor swap. thats just not right
Old May 4, 2006 | 02:51 AM
Syndacate's Avatar
ECU clicking could be a short in the ECU
Either way you need an ECU for that engine...get it..swap it...run it..
Old May 4, 2006 | 03:28 AM
wrd. you will also have to get the right harness because when you get right ecu your plugs from your old harness won't plug up.
ev94eg
Sep 25, 2011 09:45 PM
Jrfromcny
Sep 15, 2009 08:46 PM
Agent_EM1
11
Jan 27, 2009 02:24 PM
silentbeatz
Dec 16, 2008 09:44 AM
tranceologist
Aug 28, 2005 05:05 PM
