making a testpipe... where would i get flanges?
im getting ready to make my own testpipe, but i cant figure out where to get flanges for the s2000 cat. any advice? thanks
Online, local exhaust shops. 2.5" flanges, 2 bolt on header end, 3 bolt on exhaust end.
BTW, I picked up a BerkTech TP for $80. If they were charging $300 then I can understand making your own, but in this case it might almost add up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LBBP R »</TD></TR><TR><TD CLASS="quote">legally, local shop will not make test pipe. i think it'll be cheaper for you to get a test pipe, such as berk.</TD></TR></TABLE>
You can go to the shop and get the flanges though, that was the OP's question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt »</TD></TR><TR><TD CLASS="quote">Online, local exhaust shops. 2.5" flanges, 2 bolt on header end, 3 bolt on exhaust end.
BTW, I picked up a BerkTech TP for $80. If they were charging $300 then I can understand making your own, but in this case it might almost add up.</TD></TR></TABLE>
Googled up BerkTech... could not find anything. Have a link?
Thanks
Thanks
man i would just buy a test pipe instead of going through the hassel of getting the parts to do it.
projects are fun when you have the materials and tools, if not their sometimes a PITA.
yeah, i see your point about it adding up, but i like projects
anyhow, i was able to source out flanges and it should be no more then 25 bucks to make. what is required to make sure it doesnt trigger a check engine light?
thanks.
anyhow, i was able to source out flanges and it should be no more then 25 bucks to make. what is required to make sure it doesnt trigger a check engine light?thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imola-red dc2 »</TD></TR><TR><TD CLASS="quote">gotcha! ill just make a extension to push the O2 out of exhaust flow. thanks again guys
THAT will be fun!!!
</TD></TR></TABLE>THAT will be fun!!!
be forwarned you'll get a check engine light
</TD></TR></TABLE>be forwarned you'll get a check engine light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor »</TD></TR><TR><TD CLASS="quote">
be forwarned you'll get a check engine light</TD></TR></TABLE>
why would it? im gonna copy the berks testpipe.
why would it? im gonna copy the berks testpipe. </TD></TR></TABLE>
The ecu is pretty sensitive to the secondary o2 sensor. It might work for some people and might not work for others.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor »</TD></TR><TR><TD CLASS="quote">The ecu is pretty sensitive to the secondary o2 sensor. It might work for some people and might not work for others. </TD></TR></TABLE>
are you saying that berks may or may not work as well?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX »</TD></TR><TR><TD CLASS="quote">
are you saying that berks may or may not work as well? </TD></TR></TABLE>
Short of running a cat with the second o2 plugged into it, anything else is not guaranteed to work.
Spoke with Bryan at Berk and he said to expect a shipment in about 6 weeks. ( Sold out as of now) He also said it has a newer design tested on a dyno with a wideband O2. In doing this he said they smoothed out the previous designs O2 issues. Expect to see a sale on them for about 100 Shipped when they arrive.
boosted_dc2
Sep 30, 2003 03:32 PM
