cooling line heat wrap
car: 92 hatch
motor: 96 LS
Problem: Well the one hose that goes from the head to the one way check valve to the heater gets hot as hell like it should. but the problem is that it warms the return line from the rad up and heats other things too. (and i searched but no one really gave a good answer. some one said home depot heat tape.) i wanted to know what else u could use to wrap it.
thanks
if you go to summit or jegs they sell wrap that the circle track guys use, i forgot the exact name of it though, just look under cooling systems
lilxvtecxpwr
Mar 10, 2003 01:42 PM
