F22B1 swap
Old May 3, 2006 | 09:46 AM
SovietRacer's Avatar
Default F22B1 swap
i would like to know if it is possible to install the f22 into my 94 coupe. i bought the coup with a blow motor. anything will help. i would like to swap that motor in. or would it be simple to swap the b20a5 in?? cant find decent info on the f22 swap!
Modified by SovietRacer at 10:01 AM 5/4/2006
Old May 3, 2006 | 10:39 AM
HXvtec's Avatar
Default Re: F22B1 swap (SovietRacer)
id do the f22. i was thinking of doing this swap myself. its the same swap as the h22.
Old May 4, 2006 | 07:34 AM
Default Re: F22B1 swap (HXvtec)
what would i need to change???
Old May 4, 2006 | 08:01 AM
Bisimoto's Avatar
I use F22A powerplants. In both of my cars, a CRX and an Insight, I used my manufactured adapter plate system: using a D transmission mated to F/H variant engines.
The F22 (especially the A-type) has so much potential, superior inlet ports and valve angles.
Old May 4, 2006 | 08:52 AM
Default Re: F22B1 swap (Bisimoto)
man I have been doin some searchin and i cant find anything on the F22 swap. can you help me out. what else will i need to buy tho drop the motor in it??? im kinda tight on the green so hitting up the junk yard is no biggie for me!! anything will help. i need it in by the 18 of this month!!
Old May 4, 2006 | 10:11 AM
HXvtec's Avatar
motor tranny axles mounts ecu harness.... did i miss something?
Old May 4, 2006 | 10:41 AM
Rajin.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovietRacer &raquo;</TD></TR><TR><TD CLASS="quote">man I have been doin some searchin and i cant find anything on the F22 swap. can you help me out. what else will i need to buy tho drop the motor in it??? im kinda tight on the green so hitting up the junk yard is no biggie for me!! anything will help. i need it in by the 18 of this month!!</TD></TR></TABLE>
Similar process to dropping an H-series in. Sits on the same mounts, and everything.
Old May 4, 2006 | 12:35 PM
Default Re: F22B1 swap (Rajin.)
do i use the stock accord mounts???
Old May 4, 2006 | 01:13 PM
HXvtec's Avatar
they make certain mounts for this swap. its the same as a h22 swap.
93gsrhatchbrid
Apr 22, 2006 10:01 AM
eg686
Jul 11, 2005 06:56 PM
anjapower
Feb 11, 2004 07:59 PM
sivic_si
Jan 21, 2003 09:30 AM
