motor mounts
which motor mounts do i need for dropping in a b20b to a crx? is it hasbro [sorry if i spelled it wrong] but yah thtahtnthank you.
also, what else do i need.
which ecu, etc.
i wanna start asking garages to see how much theyll charge for doing the labor. ive never swaped a engine before
thanks
which ecu, etc.
thanks
I have some used (unknown brand)SOLID MOTOR mounts for B-Series into 88-91 Civic/Crx. Reason i took em off i replaced them for some hasports. let me know if intrested.
case closed, found the hasport ones. just had to do research thanks though. there about 600 bills.
if u want top quality u gotta pay top dolla
Modified by sportyballade at 12:21 AM 5/3/2006
its going to cost arm, leg and 2 nuts if its going into an 84-87. The older body doesn't make the job any easier.
p.s. I had never done an engine swap before, but I did mine anyways. There's no better time to learn than the present.
Hasports are worth the money. If you try and do the swap yourself I recommend having someone around who knows a little about it. Shops hate to finish projects. I like the older body crx's so good luck.
