clutch pedal feels soft
Old May 2, 2006 | 06:29 PM
byronl's Avatar
Default clutch pedal feels soft
My clutch pedal doesn't feel as stiff as it used to be before. It feels soft, like u don't feel much resistance from the pedal when u let off the clutch. When i put it in gear and let off the clutch it feels soft, like it's not pushing out. When i'm in neutral it feels like how it should when i let the clutch out.
recently i had a bad master cylinder and i changed it but still the same thing. I didn't change the slave because i bought new about a month ago. If the master went bad would it cause the slave to go bad as well?
Well right now i'm thinking my clutch is bad, what do u think?
Modified by byronl at 8:00 PM 5/2/2006
Old May 2, 2006 | 06:54 PM
wheelmanbg's Avatar
Default Re: clutch pedal feels soft (byronl)
sounds to me like u didn't bleed it all the way (not sure though)
Old May 2, 2006 | 06:57 PM
vlc92189's Avatar
more breakfluid.. or bleed master cylinder again.. might be air in there
Old May 2, 2006 | 06:59 PM
byronl's Avatar
Default Re: (vlc92189)
after i put in the new master i already bled the lines, I pretty sure there are no more air in the lines
Old May 2, 2006 | 07:11 PM
ballerchild's Avatar
could be your clutch going bad.. that happened to my friends db2.. and a few weeks later he blew his 6puck..
Old May 2, 2006 | 07:44 PM
SpOoLiNg CiViC's Avatar
mine did this same **** 2 weeks ago.. i could not figure it out.... but my clutch grabbed really good....
i have a b16 but does not matter... but on the front of my tranny it was the slave cylinder. i replaced my master, all the fluid...... bleed it many many times.... well my slave was not pushing out enough... so i replaced it.. 16 bucks .... works now ...
hope this helps... when u put it in make sure it's not broken or anything... and does not move.. mine did... had to get the screws redrilled...
Old May 2, 2006 | 07:53 PM
byronl's Avatar
Default Re: clutch pedal feels soft (SpOoLiNg CiViC)
hmmm, i think i'll give it a shot then changing the slave cylinder even though it's only a month old. Would a bad mc cause even a brand new slave to go bad? Cause I was driving around with a bad mc possibly when i first did the swap which was about a month ago
PaulMc
May 18, 2014 05:04 PM
sibious
Jun 13, 2008 03:53 PM
DriveSideWays
Aug 27, 2004 05:06 PM
FLCivic
Jun 30, 2004 03:48 PM
mattmw88
Sep 21, 2003 05:18 PM
