How Hard is it to take off Trunk
Im looking to switch trunks with a friend. mine has a spoiler and his doesnt. how much time will i be looking at. And also would be taking the rear window off easy also? This is for a 97 and 98 integra. will this also fit perfectly?
h/o == hold on.
and I have no idea where the pics are now, but all you do is pop off the rear head liner,
all the bolts holding it on should be under that.
why would you want to change the glass though?
Release lever isn't actually ON the hatch, but the trunk area of the car.
Not sure about the wiring, All I can think of it just cut and mark each wire of both,
make sure they're all the same then splice back together when done.
http://www.hondahookup.com/manuals
Instructions are there.
You do not want to remove the glass. It is going to be heavy.
this is the story. i found a guy that wanted to buy my stock spoiler, he had a trunk without holes in it and his rear window is tinted. and i dint want the holes in mine. so we decided to switch. but he wanted his tinted windows.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onnoff7 »</TD></TR><TR><TD CLASS="quote">is that for the trunk only or do i have to take the window off also? is it possible to take off the metal trunk part.</TD></TR></TABLE>
Removing the glass is not an easy task. It involves using a piano wire to remove the glass wihich destroys the gasket. The gasket alone is over $100.
iphatcrxi
Aug 29, 2006 05:30 PM
stizzit
Jan 4, 2004 09:28 AM
