Lights Stay On
Old May 2, 2006 | 05:24 PM
civicboisi's Avatar
Default Lights Stay On
95 Accord 2 Door Coupe EX
Turn signal lights and tail lights stay on even after the signal is off and the key is out of the ignition...drains battery now anyone have similar problems? Or know if there's a resistor to the lights somewhere?
Bone stock never been modified no alarm...
Old May 2, 2006 | 05:38 PM
HONCORD's Avatar
Default Re: Lights Stay On (civicboisi)
If yr brake lights stay on I would say, brake-light switch. but turnsignals??? u shorting out somewhere.
Wait 4 MooGoCow3 to reply he is"Da Man" in my book
Old May 2, 2006 | 05:40 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Lights Stay On (HONCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONCORD &raquo;</TD></TR><TR><TD CLASS="quote">If yr brake lights stay on I would say, brake-light switch. but turnsignals??? u shorting out somewhere.
Wait 4 MooGoCow3 to reply he is"Da Man" in my book</TD></TR></TABLE>
I don't know about all that but i'll give it a shot.
Do you mean the turn signals are steady on or flashing?
Old May 2, 2006 | 05:58 PM
Ross 2.0's Avatar
After looking at the electrical manual i think I have a few tests for you to try.
Your going to need a test light though to help you out before the end of this (you can get a cheap one from a parts store)
First of all I suspect your light switch is shorting to power. So take the column covers off and unplug the headlight switch. If the lights turn off then continue with the next steps. If not tell me and we can go from there.
(plug the connector back in)
Pull fuse #35 in your under hood fuse box, #12 in the sub fuse box under the hood, and #32 back in the under hood box.
Tell me the results of you pulling each fuse. (put the fuses back in before you pull the next)
Old May 2, 2006 | 08:40 PM
civicboisi's Avatar
Default Re: (MooGoCow3)
ok will do...the vehicles actually at the shop.
What are you using as a guide? I have Alldata to assist me also...
Old May 3, 2006 | 01:48 AM
OuttaGas's Avatar
Default Re: (civicboisi)
most likely he is using interactive network from honda
Jonathang
Oct 10, 2014 03:50 PM
JesseAccord
Jun 28, 2013 09:31 PM
beginmyhonda
Aug 4, 2011 08:01 AM
charlee
Apr 29, 2006 02:46 PM
B18EG6
Audio / Security / Video
11
Aug 3, 2005 10:28 PM
