Suspension & Brakes Theory, alignment, spring rates....
brakes
Old May 2, 2006 | 04:45 PM
ekb16's Avatar
Default brakes
is there something i have to do before i can push the piston back in on the rear brakes on a 4 wheel disk brake system....i tried opening the bleeder screw and pushin the piston back in with the tool but it wont move.
Old May 3, 2006 | 08:39 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: brakes (ekb16)
That is not what the bleeder valve is for. You only need to remove the cap from your brake fluid resivore.
The trick with the rear caliper piston is that you have to "screw" it back into the boar. It has something to do with the parking brake. Use some needle-nose pliers, stick them in the cross shaped grooves in the piston & twist it in like a big screw. If it's too hard to turn with pliers, the blade end of a crow-bar works too (I've used one). Hope I made it in time to help you out...
Skydive2144
Sep 29, 2007 01:41 AM
Dan
Apr 19, 2007 10:39 AM
dumped_ej1
Oct 23, 2005 02:00 PM
crxcess
Oct 9, 2002 10:50 AM
ken
Jul 3, 2002 08:00 PM
