ADVISE to get my goal of 220whp on a B18C6
Old May 2, 2006 | 03:46 PM
itr_dreamer's Avatar
Default ADVISE to get my goal of 220whp on a B18C6
Hi,
I'm living in Europe (Portugal) and I'm a newbie here ...
I've a B18C6 in a ITR DC2 and I want get the 220whp ... I've many doubt's about how to make this power with NA setup, without ITB's and with stock Block (pistons and connectiong rods).
This is what I've in mind:
- Head: PortFlow full job (port&polish and 3 angle valve job, with valvel for more compression...)
- CP: 12:1
- CAMS: RM M24X with RM Valvetrain
- HEADER: RMF Narrow
- Head Gasket: Buddy Club 0.4mm
<U>(Below products is what I've in my garage gaining dust )</U>
- INTAKE Manifold: Edelbrock Victor Ex
- TB: BBK 70mm
- Injectors: RC440
But I don't know if all these are a good setup and I can get my goal, can advise me with other products or other ideias?
Can stock Block B18C6 (pistons and connectiong rods), work well with 12:1 CP ???
Thank's
Dreamer
Modified by itr_dreamer at 2:31 AM 5/3/2006
Old May 2, 2006 | 04:02 PM
91' LS-VTEC's Avatar
Default Re: ADVISE to get my goal of 220whp on a B18C6 (itr_dreamer)
You should be over 200 with what your got listed.
As far as the header. Won't the straight style RMF fit in your DC?
Old May 2, 2006 | 05:05 PM
thehatchninja's Avatar
hey I'm going to portugal this summer.
Old May 2, 2006 | 06:11 PM
GetawayInMoscow's Avatar
Default Re: (thehatchninja)
I've never seen M22x's making that big of power. I think there are better options out there, even from Rocket himself...like the M24x.
Old May 2, 2006 | 06:13 PM
mx621's Avatar
i would stay away from the victorX, its gonna kill the torque, runners are pretty short. it will sacrafice midrange torque (what u want on the street), for up top power. i would just port the oem R intake manifold u have. just my .02 cents
Old May 3, 2006 | 01:44 AM
Default Re: (mx621)
About cam's I want say M24X !!!
About VictorX with my actual setup:
Intake Manifold: VictorX
TB: BBK 70mm
CAM's: BuddyClub Spec III
Head and Block: Stock
Header: Fujitsubo 4-2-1
CP: 11.2:1
Exedy Racing Flywheel 3.9 Kg
I get 183Whp and 205Nm tunned with crome but it's not finish, in HI Cam I've A/F: 11 and I'm lossing torque about 7100rpm but now I don't have inspiration to finish because I want more power
When I install VictorX the torque increase in all areas ... more notice in HiRev ...
Here a litle video of my car actually pull 2º gear about 40Km/h to 5º gear (210 Km/h) in a climb up street!
http://rapidshare.de/files/188....html
Modified by itr_dreamer at 3:47 AM 5/3/2006
Old May 3, 2006 | 03:01 AM
amazinspiderman's Avatar
Default Re: (itr_dreamer)
I'm from Portugal too, and i'm aiming a little lower than you perhaps 200whp the difference is i'm with a b16a2!
Where are you located so we can try that beast out?
And where did you get the car tuned with crome? I don't know anyone in Portugal that tunes with crome.
I just pm'ed you pls reply as soon as possible.
Old May 3, 2006 | 11:21 AM
UncleD's Avatar
Default Re: (amazinspiderman)
220 whp on a stock block......good luck man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">I've never seen M22x's making that big of power.</TD></TR></TABLE>
223whp on a conservative tune found here: https://honda-tech.com/zerothread?id=1518936
lil98civi
Apr 15, 2008 08:06 AM
MOVEOVER
Jan 27, 2007 12:45 PM
Project-D
Aug 29, 2006 08:12 PM
ITR.#1446
Jun 7, 2005 12:47 PM
NA-C5
Jan 25, 2004 01:12 PM
