i have a welder and supplies but i need some info before i start
Old May 2, 2006 | 03:15 PM
SilverDc2's Avatar
Default i have a welder and supplies but i need some info before i start
i want to make a heatshielf for my cat, the s2k on itsn't enough mine gets a little hot, makeby a radiator plate.
i have a regular mig,i have a tig welder also, along with a plasma cutter.
should i use the tig for welding aluminum?
i've only welded steel/iron thanx.
Old May 3, 2006 | 10:18 AM
I Have an STD's Avatar
wrenchin'
Default Re: i have a welder and supplies but i need some info before i start (SilverDc2-Ap1)
you can ONLY use tig to weld aluminum, cant do it with a mig (i know there is a way, but its not worth the effort)
duffman1278
Welding / Fabrication
Dec 16, 2009 05:49 PM
TheSSG
Jul 14, 2008 08:55 PM
LostAndFound
Dec 14, 2006 12:36 PM
99spanishGT
Mar 9, 2004 08:26 AM
