1988 accord fan runs constantly
Old May 2, 2006 | 03:12 PM
nmauro's Avatar
Default 1988 accord fan runs constantly
Hi,
My friends 1988 accords radiator fan runs even when the vehicle is shut off. What could cause this? Thanks in advance for the help.
Old May 2, 2006 | 05:07 PM
Ross 2.0's Avatar
In a Junkyard near you.
is this car fuel injected or not?
LX-i, LX... it makes a difference.
Old May 3, 2006 | 04:59 PM
nmauro's Avatar
Default Re: (MooGoCow3)
i believe it's fuel injected, will check tomarrow, thanks,
Old May 3, 2006 | 05:23 PM
Ross 2.0's Avatar
ok the manual isn't online so i'll have to check the hard copy 2morrow.
Old May 3, 2006 | 11:07 PM
accord-pro's Avatar
Default Re: 1988 accord fan runs constantly (nmauro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nmauro &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
My friends 1988 accords radiator fan runs even when the vehicle is shut off. What could cause this? Thanks in advance for the help.</TD></TR></TABLE>
how long does the fan run after car has been shut off??? OR
constantly = never shuts off ??
also chk to make sure radiator is not low on coolant .
Old May 6, 2006 | 10:01 AM
nmauro's Avatar
Yes, it is an LX-I, it just runs constanly after the car is shut down. Thanks for all the help so far, I'm going to have him check the coolant
Old May 6, 2006 | 01:37 PM
V6iCkSpEeD's Avatar
Im not sure but my guess is a relay!
Old May 9, 2006 | 08:18 AM
JimBlake's Avatar
Default Re: 1988 accord fan runs constantly (V6iCkSpEeD)
Fan timer module is different from the fan relays. I think the fan timer module is responsible for turning off the fan even if the fan switch is stuck.
So it's possible there's more than one problem. Stuck fan switch & bad timer module. Check the fan switch by measuring continuity thru it when it's cold. If you can rule that out, that leaves the timer.
Tdawg_1993
Jun 30, 2015 04:33 PM
clair
Aug 12, 2009 09:24 AM
chechea
Aug 8, 2007 08:56 PM
B16Power
Mar 28, 2005 11:32 PM
IrOcKtHeVOrTeC
Mar 15, 2005 10:33 AM
