about to paint my car
if you have no hookups at all anywhere from 500(for a job from a cheap place like earl sheib) up to 4500 for a color change from MOB works.
I made a post similar to this. If I can find it, I'll post it here for you. Just be cautios about people that are willing to offer "deals". I had one guy PM me that he could get it done for 1600(if I bought his header) but then he tells me because it is a friends shop he has to drive the car there and then deliver it back to me when it's finished and that I can't say it's my car. (Sound a little shady to anyone else???)
Here you go:
http://hondamarketplace.com/zerothread?id=1454751
Here you go:
DIY
dewalt 5'' RO sander @ 12rpm/w dust collection for hvac or shopair + 100' ext cord 100$
masking/sanding discs/dust mask/razorblade/filler.bondo/rubber sanding block/lint free cloth for dust and debris removal 100$
(spraygun+ air tank.... optional) pay someone to spray it if its your first time.. watch them to learn 100-1000$
Sanding discs 4 paint removal
80-grit
220-grit
400-grit
600-grit
Self-etching sealant/primer- with rust sealer/
800-grit
paint
clear coat 2-4 coats with no drying time
wetsand
1500-grit
wetsand
2000-grit
Total after purchasing paint/sanding priming yourself/masking and slipping the guy at macco a 200$ tip under the table to take care of you... then u might be happy with the results
search the forums for the other DIY paint... some blue del sol turned out pretty good
80-grit
220-grit
400-grit
600-grit
800-grit
paint
wetsand
1500-grit
wetsand
2000-grit
an where?
