damn.. water leaks.. guess where?
Old May 2, 2006 | 02:25 PM
shutta's Avatar
Default damn.. water leaks.. guess where?
So I figured out after wondering for quite a while where the water leak in my trunk is coming from.. there may be another, but the one i found today as it was raining... coming through a CRACK in my ******* rear quarter panel at the crease just above the trunk/window line. how retarded is that? now I have to have it ground clean, welded, and filled and repained... time and cash i DON'T have
another leak coming from both doors... I thought it was the window seal at the door, but that's only half the problem.. each door is cracked where the inner and outer shells weld together.. SWEET! even after I weld them back, ther ewill still be a gap between the window and the window shield.. hopefully a new seal will fix it. I don't need my polk speakers getting wet....
i'll post pics in a bit... anyone ever run into this problem?
Old May 2, 2006 | 02:56 PM
MidKnightBB6's Avatar
Default Re: damn.. water leaks.. guess where? (shutta)
nah man never had that problem. but good luck fixing it. sounds like something u wont b able to DIY
Old May 2, 2006 | 02:57 PM
limpmode's Avatar
Default Re: damn.. water leaks.. guess where? (i love my lude)
damn you are having body issues it seems. now a hole in the trunk too???
Old May 2, 2006 | 03:13 PM
prelude1897's Avatar
I know exactly where you're talking about. You have to pull back on the rain gutter thing, and water will leak in through there. A friend of mine told me about that, but I've just been too lazy to even fix it. Besides, it hasn't rainned much here lately, so I don't ever think about it
Old May 2, 2006 | 03:38 PM
chihuahuamanx's Avatar
Default Re: damn.. water leaks.. guess where? (prelude1897)
i know it sounds ghetto but... JB weld it? might sav a LOT of time money and headache.
Old May 2, 2006 | 04:55 PM
shutta's Avatar
jd weld probbaly woudl only work on the trunk area.. the doors take too much abuse.. i'll post pics probably tomorrow, i think you are getting the wrong idea about teh trunk leak one (prelude1897)
Old May 2, 2006 | 04:58 PM
asdfsad's Avatar
Default Re: (shutta)
mind posting pics of where the leak is EXACLTLY comin from? becuase i found a VERY leak but not the hole. And what year car? 4th? 5th? 3rd?
Old May 2, 2006 | 05:05 PM
shutta's Avatar
4th gen. i'llpost tomorrow
Old May 3, 2006 | 06:28 AM
Default Re: (asdfsad)
Here's where it is on the 5th Gen. It'll just slid right back. When putting it back on, be sure to align them back onto the metal clips under the rubber piece
Old May 3, 2006 | 01:39 PM
shutta's Avatar
shitty pic, but you can see some rust, and unless you look up close ot inspect it, all it looks liek is bubbled up paint and some rust
Old May 10, 2006 | 05:37 PM
asdfsad's Avatar
Default Re: (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">Here's where it is on the 5th Gen. It'll just slid right back. When putting it back on, be sure to align them back onto the metal clips under the rubber piece
did that fix your problem on the 5th gen?? Researched awhile ago and everyone is talking about cleaning out your sunroof drains and such. Know anything about that?
SilkyJohnson
19
Feb 7, 2011 07:12 PM
Dontoh
Jul 30, 2010 09:15 AM
92EGMINIME
Apr 8, 2009 12:34 AM
Barcode
Aug 3, 2006 10:44 AM
mykcuz
Honda S2000
Apr 30, 2006 09:51 AM
