question about sunroof leak on 91 si hatch, search and found some stuff but need clarification
okay more then likely it is drain tubes being clogged but i want to know for sure from guys that maybe have had this problem before
if it lightly rains its okay, nothing happens, but if its heavy rain and my car is sitting on my driveway which is inclined alittle bit not by much , i put the car in reverse after it sits for a bit collects rain i guess? then when i go to stop at a stop sign, it all pours out of the sunroof area ONLY ON THE PASSENGER SIDE, does that mean the drain tube on that side only is clogged and the driver side one is fine? or does that mean its the sunroof seal? any help would be appreciated guys, cuz currently i cannot take any passengers after it rains unless they wanna have a shower
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madmanmulligan »</TD></TR><TR><TD CLASS="quote">check the seal and if its ok its probibly your drain hose</TD></TR></TABLE>
how do you "check the seal" just see if its leaking or if there is holes in it or what?
