High Flow OBD-II Cat?
Old May 2, 2006 | 01:13 PM
DrppedAccord97's Avatar
Default High Flow OBD-II Cat?
Hello Everyone.
I'm a new person here. I had the name Intrepidv614, but I can't remember my password ( nor my answer to my question ) so I decided to just make a new one. .
Well anyways, I recently lowered my car with tein s-tech springs. Car is sitting pretty low. Especially for the roads of good old Pennsylvania.
My question is. Well I guess I bottomed out somewhere, when I first got it lowered, not knowing where I can drive fast and not, and I think I broke my catalytic convertor.
I notice a weird noise coming from under the car at somewhere between 1500-2200 rpms.
I really need to replace it, because it is annoying as hell. I have a megan racing cat-back exhaust system, that I am installing soon as well.
Friends recommended just taking off heat shield, and hollowing the cat, but with OBD-II I dont want to have a CEL.
Can someone please recommend a high-flow cat for my 97 honda accord EX( mind that I think it has a o2 sensor in it or something)? I'm only 18 and not looking forward to spending a ton of money on a cat, that I might break again right down the road, but I dont want to buy a test pipe from ebay or something because of no O2 bung.
Thanks so much Justin
Old May 2, 2006 | 01:32 PM
mattf22b1's Avatar
Default Re: High Flow OBD-II Cat? (DrppedAccord97)
go to http://www.secureleadercom.com...block
i think they have a hi-flow cat with one o2 senor for $75 + $100, are you installing your exhaust yourself?
Old May 2, 2006 | 01:53 PM
Default Re: High Flow OBD-II Cat? (mattf22b1)
No, I will be having Meineke do everything. I dont see anything on that page that says anything about having an o2 Sensor hole. I was looking at carsound ( magnaflow ) convertors, but im not sure which one will fit mine.
Old May 2, 2006 | 01:59 PM
mattf22b1's Avatar
measure your current cat and then compare the measurements given by whoever makes the aftermarket cat. this is the same magnaflow cat that's on tasauto.com
http://www.ptuning.com/html/It...20Fit
and if that one doesn't work there's a bunch of universal obd2 cats on the site
Old May 2, 2006 | 02:14 PM
I can't really measure the cat. cuz it's lowered but that's a nice cat for a good price. Can anyone verify whether this cat will work or not ??????
Thanks!!
Old May 2, 2006 | 07:02 PM
Knightmare69's Avatar
Random tech has a bolt on high flow cat for OBDII's or you can get one from http://www.Kteller.com where they can custom flange and weld on a o2 bung for you.
kevlh18
Honda Civic (2006 - 2015)
Dec 10, 2008 12:53 PM
accordinglyevil
Nov 18, 2007 05:26 PM
Cypher0117
May 2, 2006 04:58 PM
eLuderTypeS
Feb 10, 2005 12:51 PM
turbocajun
Apr 11, 2003 10:52 AM
