First nitrous, now LSDs.......My car is a drug addict
If its pulled couldn't you do it yourself?
I'd guess 1-1.5 hours labor. Here its $60/hr.
dun rite i beleive said its like 5-6 hours of labor, becaus ebasically ts a tranny rebuild and at 60 bucks an hour....welll....you can do the math
it should take about 1.5-2 hrs to do it if the tanny is pulled. <U> be sure to pull the ring gear off the old diff. and put it on the quaife!</U> <---------------- IMPORTANT!
[Modified by LoudAccord, 7:31 PM 4/9/2002]
Well, many mechanics will require 4 hours... it's a bitch to get the tranny apart and back together again correctly... i will reiterate, make sure you replace the differential bearings too!
yes, I almost forgot that, also, you need time to let it sit and dry. If you rush it, it will get f'd up. Where is that link to http://www.hondaautomotiveparts.com for the bearings?
there is a great article at http://www.hondaprelude.com
D16A6Turbo
14
Dec 2, 2002 08:49 AM
