what head gasket should I use
Old May 2, 2006 | 10:58 AM
Speed Infliction's Avatar
Default what head gasket should I use
i am running a high compression setup and think that i should use an OEM head gasket. If anybody has a better opinion would you please let me know.
12.5:1 compression
s2 pro2 cams
Old May 2, 2006 | 11:02 AM
RTW DC2R's Avatar
Default Re: what head gasket should I use (Fayzeless)
1 or 2 layer stock gasket worked great for me, never leaked. I used a liquid sealant as well to help ensure no leaks.
Old May 2, 2006 | 11:10 AM
Default Re: what head gasket should I use (clip the apex)
what brand?
Old May 2, 2006 | 12:35 PM
92TypeR's Avatar
FSAE
If you are at stock bore, or even slightly overbore, OEM 81mm is perfect. The OEM gasket is not weak by any means.
HPfreak
Sep 23, 2011 04:53 PM
chasmataz
Jul 25, 2010 08:35 AM
Joeski99Si
Apr 23, 2009 05:24 AM
bcube 1
Apr 26, 2005 10:23 PM
