Honda S2000 Honda S2000
Original oil pressure switch size?
Old May 2, 2006 | 09:45 AM
stuntman46's Avatar
Default Original oil pressure switch size?
Hello,
I would like to know what's the size of the original oil pressure switch (in mm if it's possible) on the S2K.
It is to mount an adapter for oil pressure and temperature gauges.
Thanks
Old May 2, 2006 | 11:45 AM
evil vapor's Avatar
Default Re: Original oil pressure switch size? (stuntman46)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stuntman46 &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
Thanks</TD></TR></TABLE>
Your best bet is to remove the sensor and measure the pitch and thread. It's fine thread but I can't remember the pitch. 10mm by 1.25 but I can't confirm that since I'm basing it off of memory from 3 years ago.
Old May 2, 2006 | 12:15 PM
stuntman46's Avatar
Default Re: Original oil pressure switch size? (vapor)
Thanks.
I will look before ordering
Old May 3, 2006 | 10:24 PM
Cone's Avatar
I can tell you that I just put teflon on the threads of my Defi oil pressure sender and just put it in the stock hole where the switch went. No leaks (and I track the car).
There isn't a need for the switch anyway, it comes on at ~5psi, and the Defi will beep and flash. You can unplug it and there won't be a light because the switch is the ground for the dash light.
Note: The Defi sender is quite small, almost the size of a thimble. Do NOT attempt to thread a large pressure sender (Autometer, frickin' huge) into the hole because it will break off and cause lot of problems for you.
-Andrew
DA_9
Jan 8, 2008 10:16 AM
doublejz
Jan 1, 2004 09:46 PM
Arturbo
Jan 18, 2002 06:05 AM
