What OEM header is this?
Old May 2, 2006 | 09:44 AM
Spence's Avatar
Default What OEM header is this?
Guys im about to buy this header but not sure if its what the guy says it is what do you guys think it is?
Old May 2, 2006 | 09:45 AM
dreww..'s Avatar
looks like my stock em1 exhaust manifold with some shitty test pipe bolted on to it.
Old May 2, 2006 | 09:47 AM
Mr. Bob Dobalina
Guest
Posts: n/a
Default Re: (dreww..)
That header appears to be a JDM '96 Spec ITR header or a CTR header. It is a 4-2-1 with a 2.5" collector and a smoother 2-1 merge than all of the normal OEM exhaust manifolds.
If the collector is only 2.25", it is a USDM ITR header. From the pictures you can tell it's no normal USDM sized collector, so it had to have come from some form of Type R vehicle.
Old May 2, 2006 | 09:52 AM
DC4KiD's Avatar
Default Re: (Mr. Bob Dobalina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bob Dobalina &raquo;</TD></TR><TR><TD CLASS="quote">That header appears to be a JDM '96 Spec ITR header or a CTR header. It is a 4-2-1 with a 2.5" collector and a smoother 2-1 merge than all of the normal OEM exhaust manifolds.
Old May 2, 2006 | 09:57 AM
Mr. Bob Dobalina
Guest
Posts: n/a
Default Re: (DC4KiD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4KiD &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Nobody should listen to me...I'm an '06 n00b
Old May 2, 2006 | 10:03 AM
Spence's Avatar
Default Re: What OEM header is this? (Spence)
I was told it was a Jdm Itr header! So is it doesnt seem like the top half is?
Old May 2, 2006 | 10:05 AM
Mr. Bob Dobalina
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence &raquo;</TD></TR><TR><TD CLASS="quote">I was told it was a Jdm Itr header! So is it doesnt seem like the top half is?</TD></TR></TABLE>
IT IS A JDM ITR HEADER!!!!!
It just came from a '96 Spec ITR. Only the '98 Spec ITR had the 4-1 header. The top half of all the B series VTEC manifolds are the same.
Old May 2, 2006 | 10:10 AM
Spence's Avatar
Default Re: What OEM header is this? (Mr. Bob Dobalina)
Mr. Bob i thought the top half should look like this?
Old May 2, 2006 | 10:17 AM
Mr. Bob Dobalina
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence &raquo;</TD></TR><TR><TD CLASS="quote">Mr. Bob i thought the top half should look like this?
Dude...that pic is of a '98 Spec ITR 4-1. The header you are looking at buying is a '96 Spec ITR header. The '96 Spec ITR header is TWO PIECE. The '98 Spec is ONE PIECE.
They look nothing like each other.
Old May 2, 2006 | 10:18 AM
touchmyHONDA's Avatar
that would be the 98+ spec itr (jdm) header
edit: damn bob with the quickness
Old May 2, 2006 | 10:34 AM
Spence's Avatar
ok will both styles of the header yeild the same amount of power?
Old May 2, 2006 | 10:43 AM
Mr. Bob Dobalina
Guest
Posts: n/a
Default Re: (Spence)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence &raquo;</TD></TR><TR><TD CLASS="quote">ok will both styles of the header yeild the same amount of power?</TD></TR></TABLE>
Both '96 Spec and '98 Spec ITRs were rated at 200ps (about 197hp), so I couldn't really tell you for sure.
Old May 2, 2006 | 10:45 AM
dFreezy's Avatar
IIRC, don't the USDM ITR's and pre-98 JDM ITR's have 2.0" collectors? I also think there was an older 96 spec JDM ITR header that had a 2.5" collector (but not the standard 4-1 we usually see). Not to add confusion to this issue...
Old May 2, 2006 | 10:50 AM
Mr. Bob Dobalina
Guest
Posts: n/a
Default Re: (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">IIRC, don't the USDM ITR's and pre-98 JDM ITR's have 2.0" collectors?</TD></TR></TABLE>
I'm pretty sure the JDM '96 Spec ITR manifold has a 2.5" collector.
USDM GS-Rs had a 2" collector, but I think the USDM ITR has a 2.25" collector.
USDM ITRs and pre '98 JDM ITRs just didn't have the 4-1 configuration...
Old May 2, 2006 | 10:54 AM
MITeggy17's Avatar
Damn Mr. Bob
Old May 2, 2006 | 10:56 AM
ROOROWNS's Avatar
Default Re: (MITeggy17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITeggy17 &raquo;</TD></TR><TR><TD CLASS="quote">Damn Mr. Bob </TD></TR></TABLE>
X2
He was quick with those answers.
for mr Dobalina
Old May 2, 2006 | 11:02 AM
Mr. Bob Dobalina
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .No_Honda. &raquo;</TD></TR><TR><TD CLASS="quote">
X2
for mr Dobalina</TD></TR></TABLE>
Old May 2, 2006 | 11:26 AM
Spence's Avatar
Thanks for your help you guys looks like ill pick this up from this guy he has a great price on it!
Old May 2, 2006 | 11:29 AM
dFreezy's Avatar
you might want to measure it first, there will be a difference between the 2.5" version and the others will smaller outlets...
Old May 2, 2006 | 11:45 AM
Mr. Bob Dobalina
Guest
Posts: n/a
Default Re: What OEM header is this? (dFreezy)
Just from looking at those first pics you can tell that it isn't the stock 2" collector.
The smallest it could possibly be is 2.25".
Old May 2, 2006 | 11:53 AM
babietuan323's Avatar
how much? is it worth the trouble? why not just get a used JDM DC 4-1 replica
Old May 2, 2006 | 12:16 PM
battle951sedan's Avatar
dat looks like a CTR header or a pre 98 ITR
both have 2.5" collectors. Mr. Bob is right
Old May 2, 2006 | 12:22 PM
mR. Vash's Avatar
Default Re: (jdm951EK4)
If only it would fit a d series
Old May 2, 2006 | 12:38 PM
JERKthisDC2's Avatar
95egredsi
Mar 22, 2013 07:39 AM
stuntinhb
Feb 20, 2007 12:02 AM
vtec8804
Feb 13, 2007 01:17 PM
Jdmb16sir2
Apr 29, 2006 09:33 PM
Spoonin
Jun 13, 2003 08:38 PM
