obd0 resistor box question why wont my car start
i have a b16a and i think i have obd 1 injectors. if the resistor box is still left in place what will happen, will the injectors not work at all or will they just fire wrong. my car is at a shop and the guy said that the timing is on and the spark is good its just not getting fuel. it has a pr3 ecu im not sure what is wrong the resistor box is all that comes to mind. another thing that it thought is that the main relay might be broken because that has happened before. what do you guys think. '
levi
levi
if you have obd-1 injectors then you dont need a resistor box because the injecotors are high impedance... and the box is for low impedance obd-0 injectors....
my opinion is your not getting fuel through your injectors..
You can keep the resistor box in there that is not the problem. It'll still run perfectly fine. I would check the main relay instead. My CRX has obd1 injectors in it with the stock resistor box still in place, running on a pr3 ecu. Also a friend with an ek has a crx resistor box in there for the dsm 450cc blue top injectors (turbo) but during some troubleshooting we installed the stock obd2 injectors with the resistor box still installed and it ran perfecly fine as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRinmyCRX »</TD></TR><TR><TD CLASS="quote">anyone esle have an opinion?
levi</TD></TR></TABLE>
Your rear spoiler is not high enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slpnz6 »</TD></TR><TR><TD CLASS="quote">if you have obd-1 injectors then you dont need a resistor box because the injecotors are high impedance... and the box is for low impedance obd-0 injectors....
my opinion is your not getting fuel through your injectors.. </TD></TR></TABLE>
i would agree
i would agree
Cap'N Chronic
Aug 30, 2011 02:39 PM
HatchBox
12
Jan 13, 2006 05:29 PM
