Suspension & Brakes Theory, alignment, spring rates....
Question about arp wheel studs
Old May 2, 2006 | 08:23 AM
killer1320's Avatar
Default Question about arp wheel studs
I got a 93 civic hatch and I'm have to put the arp wheel studs because of the rims and slicks I have.I was wondering if its possible to put then in without separating the wheel bearing?
Old May 2, 2006 | 08:56 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Question about arp wheel studs (killer1320)
It is possible in the rear end if the studs are the sock length. If they are extended studs I doubt they will fit.
It is not possible in the front end unless you cut a hole in the dust sheild and grind half the head off the stud. I would NOT suggest any of that if your trying to "strenghten" your hubs. And even that technique would only apply to a stock length stud...
Just rent the hub pulling tool at Autozone (or wherever). It will give you a chance to change your front wheel bearings too.
Be aware that sometimes the bearings come apart when pulling the hubs. This is a bad situation because the rear will leave the inner race stuck to the spindle. That will probably require some carful cutting, or some professional attention...
SlowB16
Jun 11, 2008 07:00 AM
TurboEK9Coupe
Sep 25, 2007 09:46 AM
erikiksaz1
Apr 9, 2007 08:32 AM
killerpenguin21
Nov 14, 2006 12:36 PM
Tyson
22
Jul 13, 2002 03:45 PM
