Obd2 to OBd1 in 99 ek hatch
Old May 2, 2006 | 08:07 AM
dank24's Avatar
Default Obd2 to OBd1 in 99 ek hatch
well I got the harness, and ecu. I pluged it in and now it revs up to 1500 and then drops over and over. What is going on here? I heard I need to replace the iacv sensor with a 2 wire one. I bought the plug and it does not fit. Can I just cut the orange wire? to make it run off the 2 wires?
Old May 2, 2006 | 11:23 AM
dank24's Avatar
anyone?
Old May 2, 2006 | 07:15 PM
dank24's Avatar
help
Old May 2, 2006 | 07:24 PM
pdiggitydogg's Avatar
First, try cleaning the iacv and its connectors, along with using some dielectric grease.
If that doesnt work, and Im sure it wont since youre implying this happened once you went obd1, unplug your evap purge soleniod connector near the plastic cover over the injectors
Old May 3, 2006 | 10:55 AM
dank24's Avatar
I read that the 96-00dx uses a 3 wire iacv, and all others use the 2 wire. Is there a way to convert it? With out a new intake mani?
Old May 3, 2006 | 11:09 AM
existanzcivicb20's Avatar
Default Re: Obd2 to OBd1 in 99 ek hatch (dank24)
ok did you use a obd2 to obd1 or a obd2b to obd1???????
Old May 3, 2006 | 11:20 AM
Ser1N's Avatar
Default Re: Obd2 to OBd1 in 99 ek hatch (existanzcivicb20)
You need to convert to 2 wire, i had the same problem.
Old May 3, 2006 | 03:58 PM
dank24's Avatar
Default Re: Obd2 to OBd1 in 99 ek hatch (Ser1N)
did you get a y8 intake then? or how did you convert it?
Old May 3, 2006 | 04:00 PM
Ser1N's Avatar
oh shoot yah sorry bro, hM I was thinking Mini me swap type of deal. I do have the y8 Intake mani
Old Jun 18, 2006 | 03:40 PM
foxcraze's Avatar
Hey man i was thinkin bout convertin to obd1 but do you still pass inspection is it legal before i waste the cash to do the full conversion i wanted to put a 92-95 b16 in it cause its a cheap swap.
3rdtimecharmer
Jan 27, 2013 01:24 PM
shahriar35
Jan 14, 2012 01:09 PM
Momentum
Aug 13, 2010 07:11 AM
boostedteggy
22
Oct 24, 2009 02:53 PM
kaoticstyles
Jun 20, 2008 03:30 PM
