k series crank sensor
Old May 2, 2006 | 07:11 AM
Hercules's Avatar
Default k series crank sensor
I need your help guys i'm running a k24a4 in a 92 cx hatch with aem ems. I have the accord k24 with rsx-s engine harness, therefor i had to put the accord crank sensor plug onto the k20 engine harness. This worked great for about 1300 miles and suddenly it crapped out. When it doesnt read either the crank/cam sensor it wont fire. So i checked for 5v at the sensor plug and the ecu pin it checked OK, my multimeter **** the bed so i couldnt check the ground on it but i just cleaned it out and it worked good last night but not today. Its like it has bad connection, it will read it and then it wont.
Now the question is do you think its the wiring or the sensor itself?
Old May 2, 2006 | 09:03 AM
Hercules's Avatar
Default Re: k series crank sensor (Hercules)
c'mon guys, i've been puttin some mileage on my feet my car is broke down a couple miles down the road.
Alright i took the sensor out and checked it, its not cracked or damaged anywhere, i cleaned it and checked my wiring and its perfect. Now its not reading the sensor whatsoever
pokmijn
Jan 7, 2008 05:47 AM
FROSTDC2
Jul 27, 2005 09:08 PM
SpeedDreamz.com
Apr 5, 2004 07:19 PM
