Blown timing-belt on my 97 lude
Hey guys, just bought a 97 lude SH and after 2 days of having it, my timing belt broke. I was doing about 135 m/h on the highway for about 3 secs. pressed the brakes to slow down because of an idiot in the left lane doing like 50, he moved over and when I pressed on the gas, it was like I was sailing in the wind
Anyways, can a broken timing belt screw up the valves? A mechanic told me not on the ludes since they are to far... I have a hard time believing him....
The last i heard - our cars are interference engines. And since you were going 135mph like an idiot, you could have bent something.
Do a leak down test on all cylinders. That will tell you if you bent anything.
Remove the spark plug, put your finger over the hole and have someone bump the starter. If your finger never gets blown off the hole (TDC), then a valve isn't seating correctly - which 98% of the time means that it is bent.
135mph = vtec
vtec = interference
interference + broken timing belt = ouch
ouch = not good
not good = your piston(s) helped close your valves
135mph = vtec
vtec = interference
ouch = not good
I took an optional warranty for 2 years and it covers mechanical parts, cost me like 450 bucks. It says it covers pistons, gaskets, motor block, and all lubrified pieces. So I guess pretty much everything is included. I see either today or tomorrow
You may be ok, but bent/broken valves are usually a sign of extreme use, ie not warranty For your sake I hope they cover it.
I would not beleive your mechanic either. I have never broken a timing belt, but the valves do overlap and can hit each other or the piston. So if your timing is all of a sudden off (or WAY off in this case), you can do some serious damage as Weatherman said.
Good luck
Also seach this site, I doubt you are the first to do this.
Good luck
I finally got an update from the mechanic: Replaced timing belt and everything is OK. No dented valves or screwed up pistons and he test drove it, working fine. He said there was not even 700 miles on it, but the person who installed it last time forgot a bolt/pin (he spoke french so dont know what it is in english) and that caused the timing belt to split in half. Cant wait to test it tonight and if everything goes well i'll be damn happy to have my lude back after only having it for 2 days
Now I just hope nothing else goes wrong...
Kike_Si
Dec 13, 2007 04:28 PM
DeDonDeRosa
Dec 16, 2005 09:40 AM
