Wipers keep on running!!!
Old May 2, 2006 | 06:18 AM
Little583's Avatar
Default Wipers keep on running!!!
Don't know whats wrong with my windshield wipers. When I turn on the car, they keep on running without being turned on. As of right now, I pulled the fuse so they stay off.
Does anybody know?
Old May 2, 2006 | 07:43 AM
snatch's Avatar
Default Re: Wipers keep on running!!! (Little583)
I think there is a wiper switch somewhere, maybe that's bad?
Old May 2, 2006 | 08:12 AM
flood's Avatar
Default Re: Wipers keep on running!!! (******)
The wiper switch could be bad or a common problem is the wiper motor istelf. I had that happen for a while and ended up putting the wiper switch between on and off. That way I could still use them.
The wiper motor has some internal wiring contacts that break. Basically it doesn't know where to stop or "park".
Mine started working half assed so I never replaced it.
Old May 2, 2006 | 10:04 AM
Relic1's Avatar
what year do you have?
After checking out both manuals, both the EK and EG wipers are wired the same so it doesn't really matter, but little things like that should be included when you ask questions like this.
cleaning the switch would be my first step.
after that check out the wiper motor to make sure that the park signal is working. If not clean that also.
Old May 2, 2006 | 10:14 AM
Little583's Avatar
Default Re: (Relic1)
sorry about that, its a 92 Si
Old May 2, 2006 | 09:07 PM
jdeemseerx's Avatar
change the wiper motor theres actually a bulletin about it so it must be a common problem
Old May 2, 2006 | 09:51 PM
B_radGSR's Avatar
on the EG they have a "mist" setting thats used by pulling the handle down (on right side of steering wheel)...Try pulling it up and see if that causes it to go off.
lxdriver
Nov 13, 2011 04:24 PM
Hondasalesman
Mar 27, 2009 09:11 AM
Juan_Mitosis
Mar 10, 2009 09:49 AM
jxhxb
Dec 22, 2007 06:02 PM
ferio 95
Mar 3, 2005 04:47 AM
