hondata question. i know you guys can answer this....
Old May 1, 2006 | 09:06 PM
soslodelsol's Avatar
Default hondata question. i know you guys can answer this....
well i was wondering if you can run hondata s200 w/ boost option with a motor that is using itb's?
also can this hondata boost option be disabled?
my setup is as follows:
LS/VTEC
ctr pistons
cometic thick head gasket
arp rod/ main, head bolts
gsr h2o pump
gsr pan
gsr girdle
itr cams
jg cam gears
954 cc itb's
440 cc blue tops
MSD Sport ignition
denso plugs
ngk plug wires
aem fpr
walbro 255 lph fuel pump
dc 4-1 header
CTR n1 crank pulley
my crx is setup for obd 1 and im using an obd 1 ecu.
so what it is yO!
Old May 1, 2006 | 10:54 PM
hitvtecgetloud09's Avatar
Default Re: hondata question. i know you guys can answer this.... (soslodelsol)
looks like you gota nice set up personally i would get better headers with the set up your running those dc's wont let your engine breath they way it should as far as the s200 with boost no u cant run that on a all motor set up and i dont think you can disable it( i could be wrong though)
Old May 1, 2006 | 10:59 PM
Default Re: hondata question. i know you guys can answer this.... (hitvtecgetloud09)
so as far as the boost option goes. i cant disable it? i need more input.
thanks for the reply
Old May 2, 2006 | 10:37 PM
anyone?
93egboosted
Mar 14, 2008 04:38 PM
soslodelsol
May 3, 2006 11:28 AM
soslodelsol
May 2, 2006 11:30 PM
DC2R714
Sep 25, 2002 08:03 AM
