Fluidyne rad install problems
Old May 1, 2006 | 08:36 PM
Mr.Death's Avatar
Default Fluidyne rad install problems
I'm having one hell of a time getting my Fluidyne 1/2 rad to fit in my crx. It's supposed to be a direct fit replacement but it's anything but that. The lower rad hose is touching the cross member and the lower mounting points are totally in the wrong place. I'm gonna have to trim the piece of metal I have marked off and fabricate mounting points where I have marked circles. Has anybody installed one of these rads in their car who might be able to shed some light on my problem. Any and all help apreaciated.
Old May 1, 2006 | 08:41 PM
ppfalcon's Avatar
Default Re: Fluidyne rad install problems (Mr.Death)
I completely cutout the section you have marked, and replaced it with a metal strip from homedepot, this is the only way I know for the 1/2 radiators to fit with a stock front crossmember..supposedly some of the aftermarket ones allow better fitment but I am not sure which ones.
Old May 1, 2006 | 08:45 PM
*Boostwerks*'s Avatar
Since when are the fluidyne 1/2 cores direct fit? Maybe for an EG, but not a CRX/EF.
Hack away my freind, and welcome too the world of EFs.
Old May 1, 2006 | 08:52 PM
Mr.Death's Avatar
Default Re: (Bryson)
Is cutting that metal going to affect the rigidity of the front end.
Old May 1, 2006 | 08:57 PM
GripDriverEF's Avatar
Default Re: (Mr.Death)
get an aftermarket crossmember. if you have the cash, get a traction bar setup. but if all youre looking for is clearance, then you should look into a new member like one from innovative or l-con. otherwise get to cuttin'
Old May 1, 2006 | 09:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">Is cutting that metal going to affect the rigidity of the front end. </TD></TR></TABLE>
No. A lot of drag cars cut that entire front peice off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GripDriverEF &raquo;</TD></TR><TR><TD CLASS="quote">get an aftermarket crossmember. if you have the cash, get a traction bar setup. but if all youre looking for is clearance, then you should look into a new member like one from innovative or l-con. otherwise get to cuttin'</TD></TR></TABLE>
Anything but the L-con POS. It's all about the Full-Race bars.
Old May 2, 2006 | 04:27 AM
crex23's Avatar
Do you guys have any pics of Fluidyne half radiators, traction bars, and turbo setup? I'm finishing my CRX and need some ideas on how to mount my half rad.
LVL RCR
Transmission & Drivetrain
Oct 28, 2017 05:06 PM
negum
Sep 7, 2008 03:41 PM
Bob_760
11
Dec 8, 2006 11:34 AM
SINISTR
Nov 13, 2006 10:26 PM
GetCaughtDead
20
Nov 4, 2004 10:11 PM
