cam gear...retard or advance?
gettin my cam gear installed tomm...what would you recommend it be set at? anything particular? and arent i able to change it whenever i feel like it?
Retard four marks or 8 degrees. I have a f22b1, btw.
I know it says 4 degrees but its really four marks on the gear which = 2 crank degrees.
The dyno runs are on my website.
[Modified by niedejb, 6:18 PM 4/9/2002]
[Modified by niedejb, 6:19 PM 4/9/2002]
comon yall anyone...i need to know...if yall are eatin dinner...its a bit late for that!!
and another kind..i cant get the bolts on this cam gear loosen for the life of me!! is there a secret?
well all you do witht he sohc is move the torquew band back and forth, there is no way to change the valve overlap, i have mine advanced 1 degree to give me a bit more mid-range, i dont rellay need to worry about up top....as that is well taken care of
You cannot just stay 8 degrees end of story. It depends on the car, state of tune, etc. Dont you need to cut that bolt or something? I know you cant just do it with a socket.
Retarding your cam timing by 8 degrees will take away all your streetable low end, but it will give you more high end... Find a nice happy median like -2 degrees, so that you have a bit of low end... if you go to the track, then retard it to whatever you want...
I recommend just going to the dyno. It is much better than anything we could tell you, since none of us have the same modifications as you.
Yes, dyno tune it please. Everyone's car is different.
I just dyno tuned my cam gear for my 6th gen. It's at 6degree retard. I gained lots of high end, and lost just a little low end.
Changing the CAM timing also changes the A/F ratio too, keep that in mind...
I reccomend not buying them. I advanced mine 2 degrees went from a 16.5s 1/4 to 16.9-17.0. The midrange was improved, but not worth the loss in top end.
Yes, but you can always change your ignition timing and cam timing to different specs... this is makes tuning more complicated...
