ummm worried
Old May 1, 2006 | 05:50 PM
steve96accord's Avatar
Default ummm worried
Ok i have a 96 accord f22b2. ok my car has a blue smoke coming out the exhaust Not alot but enuff where i can smell Oil. an its only when i first mash the gas not going up the road what could that BE? 175,000 miles any thang would be nice.
Old May 1, 2006 | 05:56 PM
Ross 2.0's Avatar
In a Junkyard near you.
EDIT: something screwy going on here... theory retracted...
Modified by MooGoCow3 at 10:16 AM 5/2/2006
Old May 1, 2006 | 06:55 PM
CD7power's Avatar
Default Re: (MooGoCow3)
how much do those cans run for?
Old May 1, 2006 | 07:06 PM
iam7head's Avatar
Default Re: (CD7power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD7power &raquo;</TD></TR><TR><TD CLASS="quote">how much do those cans run for?</TD></TR></TABLE>
i think the better question would be are they availble for the public?
Old May 2, 2006 | 05:42 AM
notoriousB's Avatar
Default Re: ummm worried (steve96accord)
guys, he's turbocharged (per the sig). adding some crap to the cylinders is most likely not going to help.
Steve, do a compression test. Your ringlands may be on their way out. Either that or your valve seals may be leaking.
If the compression test comes back OK check your turbo for leaks on the exhaust side.
Old May 2, 2006 | 08:57 AM
Ross 2.0's Avatar
The turbocharged one is a 90 Accord. The one he is asking about is a 96.
Yes anyone can buy Honda fluids and chemicals from the dealer. Just go to your nearest honda parts store and ask for it. Print off the picture if you need to.
Old May 2, 2006 | 09:04 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">The turbocharged one is a 90 Accord. The one he is asking about is a 96.</TD></TR></TABLE>
Maybe I'm blind but I don't see anything about a 90 Accord in his post or sig? Only the 96 turbo Accord is in his sig.
Old May 2, 2006 | 09:06 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">The turbocharged one is a 90 Accord. </TD></TR></TABLE>
funny his sig CLEARLY states 96. screw additives. they are not the solution.
Old May 2, 2006 | 09:15 AM
Ross 2.0's Avatar
Default Re: (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">Maybe I'm blind but I don't see anything about a 90 Accord in his post or sig? Only the 96 turbo Accord is in his sig.</TD></TR></TABLE>
what the crap.. i swear it said 90 earlier. is this some kind of conspiracy?? Mabye i need to go to bed earlier.
I retract my original theory then
Old May 2, 2006 | 01:53 PM
OK... think 4 the nice post lol but umm i only have 1 accord 96... to clear the air an all lol umm ....... bad news 4 me.. My boost Gauge was expletive'd up so... when i raced the other Night 10psi Was really 15..... so i burnt the **** up but thanks 4 the Help.....
Old May 2, 2006 | 02:40 PM
dc5_integra's Avatar
does it do it when you first start it in the morning then goes away? If so it may be valve stem seals. But from what you say it sounds kinda like it your rings are goin out.
Old May 2, 2006 | 07:00 PM
Knightmare69's Avatar
Seafoam is the same thing isn't it and it's available at autozone.
Old May 3, 2006 | 05:05 AM
notoriousB's Avatar
Default Re: (steve96accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve96accord &raquo;</TD></TR><TR><TD CLASS="quote">so i burnt the **** up </TD></TR></TABLE>
do you know what's "burnt up"? compression down?
Old May 3, 2006 | 09:03 AM
Ross 2.0's Avatar
besides my brain? I bet the rings are gizzawn
Old May 4, 2006 | 05:48 PM
RINGSSS but i just got me crower billet rods eagle pistons 9:1ratio,,, all the seals an barings.... all that other sweet **** too boost 15psi... Is there anyone with a built motor that boost over 10? if so what psi You run at the track an how u got the block bult as in parts/ratios. whats ur track times
Old May 4, 2006 | 06:21 PM
Ross 2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve96accord &raquo;</TD></TR><TR><TD CLASS="quote"> if so what psi You run at the track an how u got the block bult as in parts/ratios.</TD></TR></TABLE>
Should have asked that one a few PSI's earlier
Old May 5, 2006 | 06:09 AM
notoriousB's Avatar
I have a built motor, 8.5:1 compression, no times or dyno numbers yet as it's just started behaving for me. I built the motor myself. PSI numbers don't matter, it's the horsepower that matters.
accord96vti
Jun 6, 2006 07:24 PM
ac_attak
May 25, 2006 02:33 PM
JJ's civic
13
May 2, 2006 08:57 PM
Triblade
Feb 21, 2006 06:15 PM
GOTNOS
Apr 16, 2003 04:37 PM
