Compatible Trannies for SOHC ZC w/out changin axles or hubs?!
Old May 1, 2006 | 05:43 PM
Tippyman's Avatar
Default Compatible Trannies for SOHC ZC w/out changin axles or hubs?!
I am looking at changing my transmission in my 91 Civic Hatchback Std.
I got an SOHC ZC but the transmission is the stock four speed. It sucks soooo bad. I wanna get a 5-speed from the local pick and pull but I want to know ahead of time which trannies will work.
I need the tranny to be:
1) Five Speed
2) Compatible with SOHC ZC
3) Compatible with 91 Std. Axles and Hubs
Basically I need to know which cars (trim levels) and years will fit the above scenario?
Thank you so much in advance. And please, if you do not know what you are talking about, don't guess. I don't wanna drop a lot of money on a tranny only to have it not work!
Old May 1, 2006 | 06:24 PM
VegaS10's Avatar
ANY tranny from a 88-91 will work with your car. Try for an si.
Old May 1, 2006 | 06:48 PM
Tippyman's Avatar
Default Re: (VegaS10)
Are you sure man? I thought the splines were different or something.
Old May 1, 2006 | 07:08 PM
Crx Jimmy's Avatar
Default Re: (Tippyman)
the outer splines going into the hub is diff, the inner spline is the same
Old May 1, 2006 | 07:12 PM
Tippyman's Avatar
So, I can use any tranny so long as I keep my axles?
Old May 1, 2006 | 07:14 PM
Tippyman's Avatar
Well, is that is true, what trannies are a 5 spd.?
I know a civic/crx Si, but I can't seem to find one.
What else have them?
Please add to the list!
1)Civic Si
2)CRX Si
3)Civic DX
what other trim levels have 5 speed?
Old May 2, 2006 | 02:43 AM
VegaS10's Avatar
Just avoid the hf.
Old May 2, 2006 | 04:12 AM
slywfbpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegaS10 &raquo;</TD></TR><TR><TD CLASS="quote">Just avoid the hf.</TD></TR></TABLE>Yeah, basically, any 88-91 dx and si tranny will work that are 5 spd. I have a dx from a 91 civic in my storage room.
Old May 2, 2006 | 04:20 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure man? I thought the splines were different or something.</TD></TR></TABLE>
The inner splines are the same. ANY 1988-1991 Civic/CRX transmission will work. I actually ran an SI transmission on a Civic STD for about a year.
Old May 2, 2006 | 04:31 AM
crx_88_si's Avatar
I would only use a 90-91 Si tranny so you dont have to change your flywheel / clutch. (althought it might be a good idea to change the clutch while you're in there.
Old May 2, 2006 | 02:54 PM
Tippyman's Avatar
So are those the only cars that'll work? The DX and Si? What other trim levels?
Old May 2, 2006 | 06:46 PM
Tippyman's Avatar
If I can use any tranny, what's this about?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dough-boy &raquo;</TD></TR><TR><TD CLASS="quote">Anywho, my Honda buddy had a trans he bought as a " 91 CRX Si " and went to install in his own car, then found out it was a 88 tranny ( from the spline count which he didnt bother to check prior to exchanging cash & driving home ) & couldnt use it. </TD></TR></TABLE>
That's the spline thing I was talking about! Help!
Old May 12, 2006 | 09:14 AM
slywfbpsi's Avatar
you only have to worry about the spine count when you are trying to use your old flywheel or clutch. If you have a 91 car, the lowest you are going to be able to go is 89 if you want to keep your flywheel and clutch.
Old May 12, 2006 | 09:35 AM
crx_88_si's Avatar
what the hell do you think i meant a few posts ago?
Old May 14, 2006 | 12:41 PM
slywfbpsi's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">what the hell do you think i meant a few posts ago? </TD></TR></TABLE>I knew what the hell you meant, but apparently he didn't since he had to post the same question again. I was just reitterating it.
91tahitian.si
Nov 30, 2016 09:11 AM
Nooch
Oct 3, 2011 01:32 AM
repingjdm
Jul 25, 2010 08:06 PM
9ghtmare
Dec 22, 2008 01:20 PM
supracrx
Oct 19, 2007 01:39 PM
