tire, wheel, bearing noise?????
Have you tried rotating your tires? Sometimes wheel tire noise can be mistaken for wheel bearing noise.
Try rotating your tires first, then if the noise remains you probably have a bad wheel bearing
Sonds like a bad wheel bearing.
To check: Go about 40+ miles per hour on a SLIGHTLY curvy road. Cut your wheel into the curves n see if the sound goes away.
Turn left n if it goes away or fades to minimal its your left one. Same with the right side.
