Suspension & Brakes Theory, alignment, spring rates....
EG6 suspension help?!
Old May 1, 2006 | 03:21 PM
VTECth1s's Avatar
Default EG6 suspension help?!
95 EG6 hatch, i converted the original rear LCA's to ITR rear LCA's if want to get aftermarket coilovers, i would have to get integra coilovers from 94-01 correct? cause i currently have ITR coilovers, so i assume i would get integra coilovers again?. Thanks!
Old May 1, 2006 | 04:15 PM
Voyage34's Avatar
Default Re: EG6 suspension help?! (V8-eater)
you would have to get another set of itr coilovers.
Old May 1, 2006 | 05:08 PM
VTECth1s's Avatar
Default Re: EG6 suspension help?! (Voyage34)
it has to be ITR coilovers only, not integra coilovers from 94-01?
Old May 1, 2006 | 05:26 PM
Voyage34's Avatar
if youre talking about sleeves then that will work, but the lower mounts on itr and 94-01 teg shocks are different- not compatible
Old May 1, 2006 | 06:23 PM
VTECth1s's Avatar
the thing is all i have is just ITR lca's in the rear, and the front is still the stock, say if i bought TEIN coilovers for a 94-01 teggy it would fit on right? i want to make sure that if i buy coilovers do i get integra coilovers or can i still get civic coilovers? thats the main question.
Old May 1, 2006 | 06:44 PM
Voyage34's Avatar
the backs wouldnt...
eg/dc shocks have a u shaped lower mount that goes on the outsides of the lca/bushing. the itr shocks have the bushing integrated into the shocks, and those mount inside the lca.
aftermarket, but you get the idea
Old May 1, 2006 | 08:05 PM
1dumbscreenname's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V8-eater &raquo;</TD></TR><TR><TD CLASS="quote">it has to be ITR coilovers only, not integra coilovers from 94-01?</TD></TR></TABLE>
correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">if youre talking about sleeves then that will work, but the lower mounts on itr and 94-01 teg shocks are different- not compatible</TD></TR></TABLE>
correct.
rallyrat427
Apr 24, 2009 09:46 PM
Pikey
Suspension & Brakes
Nov 11, 2006 11:37 AM
jdm_honda_boi
Jul 23, 2006 11:42 PM
JDM SLICK
39
Jul 24, 2004 12:31 AM
