Sparco Steering Wheel Question
Old May 1, 2006 | 02:14 PM
Dunc's Avatar
BCICAN
Default Sparco Steering Wheel Question
Would these items be compatible with each other or would I need to use only a 3 bolt quick release + steering wheel? I know that I wouldn't use all the bolts on the hub, but if the holes would line up I don't see a problem with using 3 holes on the hub.
I like that steering wheel and there is no suede wheels that are 6-bolt patterns (that aren't huge in diameter).
Thanks guys.
Old May 2, 2006 | 04:33 AM
Dunc's Avatar
BCICAN
Default Re: Sparco Steering Wheel Question (AF-P Dunc)
Bump
Old May 2, 2006 | 04:38 AM
i v o u s's Avatar
well i have a sparco flash steering wheel and thats like half suede all around...and its a 6 bolt steering wheel.
Old May 2, 2006 | 08:14 AM
Dunc's Avatar
BCICAN
Default Re: (CF.Em1)
I'm going to check later, but do you know how big the stock integra (1997) wheel is? I'm just not sure if 13" would be small enough, but then again I don't know if 11 or 12" would be too small. I just need to find a dealer or something first and see haha.
Thanks for the reply man
EDIT: I just took a look at your garage link, that's one damn clean car
Old May 2, 2006 | 09:16 AM
Erik95LS's Avatar
Default Re: (AF-P Dunc)
you could simply give sparco a call and find out in about 2 seconds.
Old May 2, 2006 | 12:12 PM
Dunc's Avatar
BCICAN
Default Re: (Erik95LS)
Now that'd be too easy haha
Old May 3, 2006 | 08:07 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">you could simply give sparco a call and find out in about 2 seconds. </TD></TR></TABLE>
Ok so I broke down and called up a dealer haha
FYI: Here is what I was told for anyone would might search this topic down the road:
- The stock integra DC2/4 wheel is 14" or 350mm. The "industry standard" for performance wheels is 350mm. I was thinking of the 285mm wheel but I guess that is a "really really really really tiny wheel. It's basically a kart or F1 sized wheel, and you would have serious issues with it" (Issues in terms of ease of use). It sounds like the 330mm is the smallest a person should go with a car of this size.
- Also, the 3-bolt and 6-bolt quick releases & steering wheels have different bolt patterns. So you would not be able to bolt a 3-bolt wheel to the "tuner" quick release or a hub adapter.
Hope this helps anyone wondering the same in the future.
CBEengineering
Dec 7, 2006 03:15 PM
ff-formula
Dec 26, 2001 07:18 AM
