Gutting the Lude
i have a 4th gen, and i want to take out the back seat (especially because they get wet). i was wondering if anyone knew the correct way to do it without breaking anything so incase i want to put it back.
THanks
THanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulud »</TD></TR><TR><TD CLASS="quote">i have a 4th gen, and i want to take out the back seat (especially because they get wet). i was wondering if anyone knew the correct way to do it without breaking anything so incase i want to put it back.
THanks</TD></TR></TABLE>
I gotta ask....your back seats get wet? You gotta get girls that swallow...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apeng09 »</TD></TR><TR><TD CLASS="quote">remove lower seat @ brakets underneath. on the driver side cushion you pull up and pull out. on the pass side cushion you unbolt it from the hinges</TD></TR></TABLE>
does that also get out the back of the seats?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Sober »</TD></TR><TR><TD CLASS="quote">
I gotta ask....your back seats get wet? You gotta get girls that swallow...</TD></TR></TABLE>
hahahahaha
hahahahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Sober »</TD></TR><TR><TD CLASS="quote">I gotta ask....your back seats get wet? You gotta get girls that swallow...</TD></TR></TABLE>
Wow, great advice
Wow, great advice
well on my 5th gen u drop the rear seats then theres these 2 bolts under the cover of the back ..then push down on the cushion then theses little tabs should pop out then u can remove the bottom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thats fresh »</TD></TR><TR><TD CLASS="quote">well on my 5th gen u drop the rear seats then theres these 2 bolts under the cover of the back ..then push down on the cushion then theses little tabs should pop out then u can remove the bottom</TD></TR></TABLE>
ill keep that in mind when i gut mine
its very EASY ive taken mine out twice and put back in twice. just look at it. pull the tabs on the bottom of the seats to remove those and just look...youll see what bolts need to go out next.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 »</TD></TR><TR><TD CLASS="quote">its very EASY ive taken mine out twice and put back in twice. just look at it. pull the tabs on the bottom of the seats to remove those and just look...youll see what bolts need to go out next.</TD></TR></TABLE>
ok cool i havent even look at it yet, just decided im going to and figured i would ask first to not expletive anything up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GtechPro »</TD></TR><TR><TD CLASS="quote">
Wow, great advice
Wow, you're a tool.
Do n00bs still use Gtech meters? I thought those went the way of pagers...
Wow, great advice
</TD></TR></TABLE>Wow, you're a tool.
yeah Gtech=
only time we ever tried one we set it up according to directions... it told me my STOCK (at the time) 5th gen had 243 hp and did a 13 sec 1/4.......
damn my car is the ****
