how to install short throw shifter adapater
Old May 1, 2006 | 11:21 AM
eagleclawracing's Avatar
Default how to install short throw shifter adapater
How would i install my short throw shifter adaper on my 94 accord? pics if any body has any or an instuction manual
Old May 1, 2006 | 12:44 PM
cats_on_ice's Avatar
Default Re: how to install short throw shifter adapater (eagleclawracing)
Well, this isn't your car (1 Gen older) and it's not <U>really</U> instructions per-se.
But whatever nobody's said anything yet. Maybe you'll have a eureka moment!
http://cb7tuner.com/vbb/showthread.php?t=46210
Old May 1, 2006 | 03:46 PM
mattf22b1's Avatar
Default Re: how to install short throw shifter adapater (cats_on_ice)
First you have to remove the center console, there are a couple of screws in the drivers arm rest and a couple of clips then you can lift the whole thing up, remove the shift **** by pulling the plastic part that connects the **** to the leather boot, when you have done that remove all connectors from the radio cigarette lighter hazard lights etc...once you have done that you should be able to access the shifter and where the adapter will go, you have to unscrew the bolt that holds the whole thing together it goes through the bushing and the shift link cable. the whatever adapter it is place it in the correct way up screw the bolt back in and secure, then you should be done.
Modified by mattf22b1 at 6:58 PM 5/1/2006
jokerstone
Sep 4, 2007 10:26 AM
I Am White
Mar 14, 2007 05:47 AM
AccordSleeperZzZ
Oct 18, 2006 09:28 AM
lif3tak3n
Dec 2, 2005 08:16 AM
erikjohn19
Sep 28, 2001 10:48 AM
