rear sway bar
Old Apr 9, 2002 | 11:49 AM
toadlax's Avatar
Default rear sway bar
My rear sway bar is seperated from the tie bar that connects to the rear suspension, should I spend the money
and upgrade to a perfomance bar? Im in the process of upgrading my suspension and planned on changing the sway
bars in the future but im currently saving for a set of koni yellows to go with my H&R springs , so should i get the
sway bar or, just fix the stock one and get the shocks done??
Old Apr 9, 2002 | 11:53 AM
briq4's Avatar
Default Re: rear sway bar (toadlax)
Get a new aftermarket one, the difference in handling is amazing. The stock bar is VERY weak. you can bend it by hand, a replacement one is like 3 times as thick and very solid. I would say don't waste the money on a new stock setup. Also the aftermarket one does not use the stock body mounting locations so you wont even have to buy new brackets. The ones that come with the new kit are great. I have the Suspension Techniques bars and I really like them.
Good luck~!
Old Apr 9, 2002 | 11:56 AM
briq4's Avatar
Default Re: rear sway bar (briq4)
P.S. I wouldn't get the set... I don't think it's necessary, the front bar is much larger than the stock one and is not hollow, it still dials in a bit of understeer, I'd rather it be more tail happy than plow happy.
Just my .02
toadlax's Avatar
thanx for the quick info, where can i find a suspension techniques bar??
Old Apr 9, 2002 | 12:17 PM
Gennady's Avatar
New User
If your are stressed for cash, I will be parting with my stock rear sway bar for mere pennies in the future.
Old Apr 9, 2002 | 12:19 PM
Conechaser's Avatar
Default Re: rear sway bar (Wont be beat)
Actually the ST front swaybar is the same size as the stock one, however, it is more rigid than the stock one.
I personally just got the rear ST bar, i couldn't tell a real big difference, but I would def recommend it to anyone
Old Apr 9, 2002 | 12:31 PM
SOHCArchangel's Avatar
Default Re: rear sway bar (94Accord)
well mine is sitting in my living room and i cant wait to install it
Old Apr 9, 2002 | 12:46 PM
sleeperaccordv6's Avatar
From: west Ft.Worth, Texas, the big one in the center
Default Re: rear sway bar (SOHCArchangel)
I've got susp. tech. on my accord v6 and love them,yes there is some understear,
but I plan on putting eibach strut bars on front and rear so hopefuly that will
correct some of that....
Old Apr 9, 2002 | 12:56 PM
briq4's Avatar
sorry didn't mean larger just meant wider. the distance from end mount to end mount is farther than the stock bar was.
I got mine from http://www.lightningmotorsports.com/
They have them for $130.90 for just the rear bar.
Old Apr 9, 2002 | 03:33 PM
toadlax's Avatar
Hey wont-be-beat
what years will your bar fit, mines a 99 4-cyl sedan, if it fits, Id like to have it. thanx
Old Jun 23, 2002 | 09:12 PM
Razor's Avatar
i just ordered my neuspeed black front upper strut bar for 89 bucks, and my s/t rear sway bar for 129 bucks from http://www.shox.com.(best prices)
can't wait to install it, just get the rear...i like oversteer.
Old Jun 24, 2002 | 04:34 AM
YeuEmMaiMai's Avatar
does that include all of the nessescary mounting hardware?
Thanks
Old Jun 24, 2002 | 04:40 AM
Default Re: rear sway bar (YeuEmMaiMai)
Thanks
yes man
Old Jun 24, 2002 | 12:36 PM
Gennady's Avatar
New User
Hey wont-be-beat
Sorry dude, wont fit. Mine is only good for 90-93 DX models.
Old Jun 25, 2002 | 08:10 PM
ArchAngel Sabastian's Avatar
New User
is there any diff from the 5th gen v6 / 4cyl sway bar's?
Old Jun 26, 2002 | 06:58 AM
Gennady's Avatar
New User
Default Re: rear sway bar (Sabastian)
Shouldnt be. Best way to check is hondaautomotiveparts.com
myblkVTEC
Nov 11, 2012 11:11 AM
MaaseyRacer
Aug 17, 2004 09:40 PM
Deam
Jun 29, 2004 01:07 PM
Jordan_4WS
Feb 22, 2002 12:41 AM
Gennady
Jan 11, 2002 05:30 PM
